1st LS build - feedback please
Looking to build 1st Ls motor. Here are the details:
LS2 block - squared, minimal material removed
Wiseco 4.005 forged pistons -3.2cc
Stock - 3.622 crank, polished
Forged 6.125 / .927 pin rods
AI 232cc heads, 65cc chambers
ARP main studs
ARP head studs
Willing be installing another LG GX5B 232/238 114 camshaft. Had a lifter go bad an take it out.
Target is 10.4 compression. Am I on target? Feedback gladly welcomed.
Car had ECS blower kit on it with stock motor, made 711/644 to wheels. Power target is 825/710. Will be turn boost up to 10-12psi
Thanks
ARP main studs
ARP head studs
Thanks
looks like a solid plan to me. Are you going to line hone the mains? If not, I recommend checking for bore distortion with the main studs.
What plans for the valvetrain?
Moderator
ARP main studs
ARP head studs
Thanks
ARP main studs
ARP head studs
Thanks
Use an online calculator to figure out what you need to get the CR you're looking for. Personally, I'd drop it a little lower than 10.4:1.
Link
