Which oil pan will clear 4.125 crankshaft (F-Body)
Hi,
I did search the forum and outcome is :-
- Stock F-Body oil pan will not fit but need modification if you want to.
- Moroso oil pan 21150.
The questions are
1. Will Mosoro oil pan clear the Compstar 4.125 crankshaft ?
2. I cannot judge from the pictures if it needs to remote mount the oil filter or not !
THANX
The questions are
THANX
I am using the Holley 302-1 oil pan and it clears my 4.100" crankshaft with no problems. Motor is a LS3 based 427. Note: the Holley 302-2 oil pan will not clear unless you do some modifications to it.
