PISTONS INFO, please
Bushed rod has a bushing in the pin bore. Full floating rods typically have this bushing, meaning that the wrist pin is not a press fit into the rod. The piston is also designed around this, as a full floating piston will have locks holding the wrist pin on either side, as a press fit piston will not. You can put a floating piston on a press fit rod, but you can't put a press fit piston on a floating rod.
