Can I rebuild my LS3 into a LS7 427 CI?
Seen a pair of LS7 heads sell for 1100 bucks on here less than a month ago.
Call CBM I think they have 5 sets of LS7 heads for 1500 CNC machined by them.
Almost forgot to mention it not uncommon to see a guy with a resleeved block run a 4.125 stroke also. The darton sleeves are longer than the factory therefore keeping the piston up in the cylinder wall for better stability and reliability.
Now with a motor at 4.125 bore you can virtually have endless head options. You can run a basic 317 head to a big valve LS7 mast head
Now let's talk about the money part of the deal. Think about this for thought and compare for yourself.
~GM LSX block is 2500-2800 bucks from Jegs....weight is 230 lbs
~Darton dry sleeve block procedure is 1800-2000 max bucks ..... weight is 105 lbs
~RHS block..... let's not even go there cause we both know it's north of 4 grand.... cost is higher than a giraffe @$$
☆power adder combinations need to stay at 4.155 bore or less due to cylinder wall thickness and head gasket sealing off nice and tight.
Lucky for me I picked up a 5.3 aluminum block on Martin Luther King day for on 250 bucks and that block turns out to be the most rigidity GM block that can be resleeved I'm one happy camper.
