l92 heads on ls2
l92 heads on ls2
hi im new to this, just got my 06 gto last yr and was wondering what kind of compression i should run on ported and polished l92 heads with my stock ls2 engine. i eventually want to rebuild the bottom end and run a procharger. Any info on how much and the best deal would be helpful as i've been looking at these http://www.texas-speed.com/p-4008-pr...der-heads.aspx they also offer 260cc cnc heads
Thanks so im guessing 68cc with the heads and any word on the cam? i know lingenfelter offers several different hyd roller cams as well as comp cams... what will fit and will still idle smooth while allowing for alot of hp gain?
Using L92 heads with a stock gasket (lowering the compression ever so slightly) I made 475rhp on my LS2 with just head, longtubes and a Englandgreen Mayhem II cam. Threw on a Vortech Si and made 675 on e85.
How much clearance did you have? Do you think you could have got away with a .040 gasket?
JIM
http://www.englandgreen.com/ my ear tells me the .050" duration number must be about 238-240 range
you're not fooling anybody at the stop light with that stick....LOL
