First Ls based build with a couple quick questions.
So far I've got a ls2 short block, long tubes, a set of 243 heads, ls6 intake and throttle body with some 42# injectors.
Going to stay n/a with the build and cam only.
I'm stuck on picking a cam and have flipped back and forth between the tick ls2 polluter and btr ls2 stage 3/4 cams. Not sure if I'm stepping to deep into cam selection or if I need to dial it back a bit. Not sure if the ~620 lift is going to cause a sense of worry for ptv in stock form.
Ideally I would like to be low to mid 400.
