“Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
Old 10-27-2015, 11:09 PM
Super Hulk Smash
JakeFusion's Avatar
Those Dart Pro 1 Heads are pretty awesome.
What lifters are you using? It says Cam Motion in the article? Did you go with a Bushed lifter? Or a needle bearing? Any concern for longevity? Or is the LLR mild enough to not worry?
Old 10-27-2015, 11:19 PM
Old School Heavy
speedtigger's Avatar
The LLRs are mild enough not to worry. But, these lifters have pressure axle oiling. So, double insurance.
Old 10-27-2015, 11:32 PM
Super Hulk Smash
JakeFusion's Avatar
Sounds good. Are they the Ultra Pros rebranded? You know I've been kicking this around for a while... lol
Old 10-27-2015, 11:35 PM
Old School Heavy
No. These lifter are manufactured in Florida by some guys that used to work for Crane Cams. Kip has the hookup on these.
Old 10-28-2015, 12:20 AM
Millenium Z06's Avatar
Nice!!
Old 10-28-2015, 07:56 AM
ragtopz28's Avatar
Originally Posted by speedtigger
So much for the LS3 heads don't work on a 4" bore argument eh? LOL
Are you going to the private track rental on November 8th?
I've already sourced some ported L92's and other top-end stuff and decided that I wanted the 402 over the 408 for the weight savings (what's 6 cubes right!).
I had planned to go to the MM shoot out and heard about the track rental. My S60 is on order and I took my car for a spin this weekend and the old 10 bolt was making 'some new weird noises' so I don't want to risk it blowing and taking out my trans. I may ride up to watch though...
Old 10-28-2015, 08:32 AM
KCS
Moderator
KCS's Avatar
Man! As cast heads making 700hp on a small block and pump gas. That's pretty sweet.
Old 10-28-2015, 08:52 AM
Rise of the Phoenix's Avatar
I wonder how much these heads would pick up in ported form?
Old 10-28-2015, 09:30 AM
Old School Heavy
Also, I want to give a big thumbs up to the Daytona Sensors Smart Spark ignition system. It performed flawlessly while our MSD 6010 ignition box was acting up. It exhibited excellent spark all the way to 7500 where the test ended.
Old 10-28-2015, 09:42 AM
KCS
Moderator
KCS's Avatar
What do you have going on with the bolts on the valvecovers? Those are Proforms, right?
Old 10-28-2015, 10:13 AM
Old School Heavy
Yes. I went with different bolts and different rubber backed washers. The allen bolts and washers that came with the valve covers kept loosening up. One actually fell out. These are hanging in there nicely.
Old 10-28-2015, 10:56 AM
  #32
Exact covers I have and the same problem, I used blue locktite on new stainless allen bolts and thicker rubber washers but am going to go to rubber backed metal washers when I do the proform vent mod.
Old 10-28-2015, 11:01 AM
  #33
Old School Heavy
I got the rubber-backed steel washers from Home Depot believe it or not. So far, so good.
Old 10-28-2015, 11:38 AM
  #34
ragtopz28's Avatar
Originally Posted by M.BOZZ
Changing direction ragtop ? That 403 is awesome
After seeing this post ...no doubt. Looks like I have a 6.0 block for sale!
Old 10-28-2015, 12:06 PM
  #35
KCS
Moderator
KCS's Avatar
Good to know, thanks. I have the same ones but haven't used them yet. Looks like I'll be looking for bolts and washers.
Old 10-28-2015, 04:23 PM
  #36
Bowtiedford's Avatar
man, might have to rethink my combo since I think I washed down my rings in my 428
Old 10-28-2015, 06:53 PM
  #37
Old School Heavy
Here is what I used for sealing washers:
http://datasheets.globalspec.com/ds/...6-CE7071595603
You can use whatever bolt suits your fancy. I like the look of the flanged bolts.
Get with me on your engine. I have an idea of what killed it.
Old 10-28-2015, 11:39 PM
  #38
Thats where most of my non critical bolts come from. Lol
Old 10-29-2015, 07:26 AM
  #39
HighspeedLean's Avatar
What total timing did you end up with and were you still on the TR6 plugs?
Old 10-29-2015, 08:03 AM
  #40
Old School Heavy
We started at 26 degrees timing and kept increasing until the engine stopped making more power and wanting more fuel. The engine did not make any more power on 32 degrees than it did on 31 degrees, so we stopped there. The plugs for the dyno session were TR6. We will see how they look after 1320' of heat.
Quick Reply: “Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
