“Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
#122
To Darin: Are you liking the CID intake more than the Holley High Ram?
* Good guy. I have No complaints non @ all on the product delivered. This is not my engine rather I'm a subscriber of Reher on YouTube.
That depends on the camming, engine cid and intended rpm range of the engine. If you r running in the 3000 to 7500rpm range then the Holley ram. If you’re in the 5500 to 8500+ range, then use the CID.
#123
RPM is a beautiful symphony.
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com • ☎ 225-926-6110 • Like Us On Facebook!
The following 2 users liked this post by DualQuadDave:
Che70velle (01-04-2024), G Atsma (01-04-2024)
