Shaft Mounts for TFS 255 LS3 Heads
I'm wanting to run the T&D Shaft mounts, but given that the TFS heads use a little different valve spacing (12 degree and LS7 valves), are they any T&D shafts that would work?
I know they make a cathedral specific TFS head with an offset, but didn't know if the LS3 would work. If not, should I look at Crower?
It's more like $1300 if you find it in the right place. Which is about what the T&Ds run... but they are aluminum.
I'd prefer steel. It doesn't fatigue the same way. And with a solid roller setup, weight is less of an issue. Plus, I'll be running the Hollow-Stem REV valves in the TFS 255s.
Shaft mount LS3 rockers...
I have the GenX 255 ls3 heads and using T&D machine shaft mount rockers specific to these heads, I ordered mines with the lighting option which consists of line across the center about an 1/8 deep and prov 1/4 wide.
Been using T&D machine rockers for a while in several different LLSR engines without fail they are very sturdy and have several different options you can have if you call them.
Their racer service program is very good send back the kit and they inspect through and replace worn parts and ship it back to me for the cost of the parts plus shipping only.
I keep waffling on the medium bore LS7s vs the LS3s. The TFS heads are essentially LS7 heads but with the less effective LS3 manifold. That's why I'm looking at all the options.
But those Crowers look damn good. I like the priority oiling. T&D has those as well at this price point.
TFS 260 is an LS7 based head. Have you looked at it? I built a 427 based on LS3 so I went with the 255s as I originally planned to reuse the intake and valve train. Of course in the end the build morphed and I ended up running a FAST intake and Yella Terra rockers. Ultimately could have gone LS7 based though with Mamo working everything I am not sure I really left anything on the table.
Originally Posted by JakeFusion
I'm wondering if the 260 will fit an LS3 bore?
And on the 4.070" bore, I don't know if there is anything different between the 255 and 260s. It comes down to the manifold.
A friend put a Mamo ported FAST LS3 on his Mast headed LS3 and LOST power all across the board over a ported stocker
Thats the problem, the LS3's maybe a little more reliable in the VT area but you pay for that with the restrictive intake. I'd contemplate a set of Dart or TFS LS3 heads but the intakes suck.
416.
Boost does cure any Worry about intakes
So what do you think is the best intake option for the LS3 heads? I know the FAST LS3 is a waste of money. I seen the Nelson Racing cross ram w/ dual 90 mm TBs they had on their 496 & it made 60 hp over a FAST 102 but I wonder how it would work on a 416? & if it fits under the cowl of a 4th gen?
Well, this puts me back to the Crawford Racing LS3 intake. I have the LS3 rails and the LS3-sized L92 Flex Fuel injectors. So that'll all work nicely. I'll just have to fab up something for the Cable-driven TB.
I'll just have to pick up a 92mm TB... even though I have both a NW and FAST 102 sitting here. Sigh.
What's funny (or sad) is the FAST w/102 is still down vs a Crawford LS3 with a 90mm... wtf FAST.
Actually, is the MSD Airforce ever coming out for the LS3? It might be the ticket...
The other option is the Holley Hi-Ram. But that would require hacking up the car to make it fit.
