ls7 434ci low power!!!
hi
I have I don't know what to say , the car work fine put the power is very low
I have corvette c6 Z06 with 434ci high compression
LS7 434ci
13.8:1 compression
mast 305 milled to 60cc chamber with PAC racing valve springs .700 lift
fast 102
243/254 .661/.661 113+3
hydraulic roller
1.8 rockers
8.000 pushrods
use Q16 we get only 594whp 556wtq
the power drop after 6000 rpm
what is the problem ??
is this the max power ??
LS7 434ci
13.8:1 compression
fast 102
hydraulic roller
1.8 rockers
8.000 pushrods
What kind of dyno?
What kind of lifters is you running ?
The lifters can be the problem.... I've been told over and over the LS7 lifters can rob a couple horsepower in the high rpm range which sounds like is happening to you.
On another note dynos are just for tuning and at 590 plus at the tire I'll be more interested in seeing your trap speed at the track. It tells the real story. You have a respectable number at the tire there. That's roughly 700 horse at the crank!! Some larger 454 LsX motors don't even make that.
I think the cam is too small I have a 447 ci same compression roughly with big cathedral heads with a 102 and my cam is 263/271. Also have you looked into e85? Before I changed the cam or anything I'd run it at the track. Dyno numbers are irrelevant, my car on one dyno made 466 rwhp but it's been 9.77 breaking up
