How many Rpms are you turning your stroker?
Planning an ls3 427ci build. Looking to set the limiter at 7800rpms. Has anyone had any piston skirt wear problems with their stroker? I know the big stroke pulls the skirt out of the bore but is this as serious as they make it sound? This will be a DRAG CAR ONLY. So milage will be limited.
Please post setups and your experience. As well as a piston manufacturer u recommend. Might be sending the pistons out to get the skirts coated by swain tech for safety.
Thanks
Thanks
Planning an ls3 427ci build. Looking to set the limiter at 7800rpms. Has anyone had any piston skirt wear problems with their stroker? I know the big stroke pulls the skirt out of the bore but is this as serious as they make it sound? This will be a DRAG CAR ONLY. So milage will be limited......
If not, you may want to go with a 4" stroke.
KW
Moderator
Thanks
Thanks
As for RPM, 4.1" is really nothing. I used to build 4.5" stroke BBC engines with heavy rods and pistons that would live at 5500-6500RPM for hours. A 4.1" small block crank at 7800RPM would be cake.
i see alot of people running a 427 with an ls3 block so i couldnt imagine it would be that bad of a problem. its going in what was an original 66 corvette big block 427 turbo jet car. would be cool to match the 427 LS to match the car.
Anyone saying it's a bad idea have any personal experience with it? Or are you just relaying the Internet claims to me? Any engine builders actually take an engine apart and see wear on the pistons to a point it had to be replaced?
