Cam Motion's New Titan LS3 Cams
LS1Tech Sponsor
Cam Motion is proud to announce our new Titan LS3 cams. These camshafts were specifically created for LS3, L99s and similar engines equipped with rectangle port cylinder heads and factory style, FAST style or MSD ATOMIC Air Force style intake manifolds. From mild to full kill, we have you covered.
http://store.cammotion.com/catalog/s...word=titan+ls3
These cams are available in 5150, 8660 and our top of the line 8620 cam cores.
And, as always, if you don't see the exact cam you want, we will make a custom grind at no extra cost to you.
Just out of curiosity, where do you come up with the RPM range on these cams? I have been looking at a variety of cams and a similar cam from somebody else shows maybe a 2800-6500 range where as you might show 3500-6700. For example, why is the Big Lope have a lower RPM band that the Titan King? Looking at the specs, I might assume they would be opposite each other.
LS1Tech Sponsor
The Titan series LS3 cams and their recommended parameters are based on how it should behave in an LS3. The big nasty series are more general.
If you want to talk about your specific engine, just email Kip. Kip@CamMotion.com. He will help you make the right choice.
I wish someone would post some VVT results.
LS1Tech Sponsor
We make a lot of VVT cams for Gwatney Performance. They have shared a lot of their results. Check them out: https://www.facebook.com/GwatneyPerformance
