Bad tick after cam install and deleting afm/dod
Ok, got BTR stage 2 cam. Everything went together fine, ls7 lifters, ls2 trays. Go get it tuned, running great, 3rd pull had a bad knock at around 6k rpm. Oil pressure is roughly 50 at wot. 35 at warm idle. Runs great even when tick is present. Tick only appears when warm. Sometimes even just cruising on flat ground. I didn't measure push rods as BTR said 7.4 would be fine. They were a hair bigger than stock rods. Thinking maybe push rod too big? Any thoughts are welcome, thank you!
Is it a tick or a knock, that's a big difference you mentioned that it knocked. And if you didn't measure for pushrod length, they may be to short causing your ticking. I highly doubt they are too long and collapsed a lifter. You may want to take your valve covers off to inspect and make sure everything is still tight.
i made sure everything was tight and still tick, BTR says sounds like a lifter with the oil squirting weird. just pulled head and lifters, lifters all roll smooth, #5 cylinder where the oil was weird, a lifter has a definite line on it, its smooth can't feel it though. Hoping it didn't damage cam
How is that a problem? Calls for 5w30? It only makes the tick when warm. I mean it was an obvious lifter tho. When valve cover was pulled I had oil barely pumping over rockers at idle and then #5 exhaust would randomly squirt on the booster. BTR said sounds like trash got in lifter causing it to do that.. Check out pictures on my other thread. I'm
Nervous the cam is bad or hurt
5w30 shouldn't thin after being warm. 5 only represents the cold start up, should still stay the same when warm. Hell I use 5w30 amsoil on my Camaro, 82k miles runs great and engine noise isn't loud at all. Maybe I will try 10w40 in the truck after I put new lifters in
The following users liked this post:
Daniel T Woods (04-07-2020)
I Had something similar happen to me after a cam swap. Turned out the oil pump pickup o-ring was clipped when I put the pickup back on. So it was sucking in air and oil and frothing up and the first lifter to get the oil (#7) didn't want to pump up and when it warmed up it would tick pretty bad.
No, it's not.
5w-30 warms up to a 30 weight oil. Just like your 15w-40 warms up to a 40 weight oil. Your oil just has shittier cold flow properties than the 5w does.
It's the LS7 lifter inconsistent bleed down rate. Sometimes they stay pumped up, sometimes they bleed down at lower rpm causing the noise. I've had the same issues with mine which is why they're coming out for the 5315s.
If it was quiet and then got louder over time, it's likely the lifters. If it's quiet sometimes and louder during other times, that sounds like lifters too.
If it was something worse, the sound would not come and go, it would be constant.
For what it's worth, my G8 is exhibiting the same behavior. Some day it sounds fine, but after really long drives (hot oil), it gets very clackity.
Take a video and post it, it makes it easier to determine what the sound is.
You HAVE to measure pushrods. Quick way to check, pop your VC off, loosen two of your rockers that are off the cam lobe with the valve closed, bottom the rocker bolt down just until it stops, mark your socket with a line, and set your torque wrench to 22 ft lbs, you want that line to make 1 1/2 turns before it clicks.
