Assistance placing these gaskets
I purchased an LS2 and it was completely disassembled, so I did not have the luxury of taking it apart to see where all the gaskets were. I've done a fair bit of searching and still need help with the below.
The kit is Felpro and it seems it is for a few different applications maybe.
in this bag there are 8 injector O-rings, but I'm not sure what the (4) smaller black ones are for.
There were two different styles of water pump gaskets, I assume the metal ones would work in my case.
These two were in with the water pump gaskets, and no clue about them
Numbered from left to right.
1- These two I am almost certain are for pickup tube
2- Small O-ring, no clue
3- looks like a drain plug O-ring
4- looks like a drain plug O-ring
5-Shaped metal, no clue
6-no clue
7-no clue
8-no clue
9-looks like pickup tube O-ring
10-Tiny O-ring no clue
6-no clue
7-no clue
8-no clue
Believe they're for those who are brave enough to try and rebuild the pump
5-Shaped metal, no clue EGR fitting on exh manifold?
6-no clue This and #7 look like seals for the doo-hickey on the side of the oil pan
7-no clue
8-no clue
7-no clue
8-no clue
After a bit more research it looks like a few of the gaskets are for the LT family of engines as well.
Thanks for your response!
