ERL is closing and Moving ON!
#41
You were saying?
Not real sure what you issue is nor do I care. Steve @RED explained to me his Process and ERL did theres at my time of purchase. If they've changed since then, great
#42
You say one thing in one post, and then act like that is not what you say in
another. If you are going to post something, post accurate info, not just something you assume is correct.
You post a link to read about the super deck 6, and act like that proves a point.
So where is the 5th bolt hole? and how do you access it? Come up with that answer.
#43
Not a single post of mine referenced a 5th bolt. I spoke to the 6 bolt hole and 6 bolt heads on the outboard side of the block.
As for who's an idiot, only the superdeck was available with the 6th bolt option so it stands to reason thats what Id post. As for the lifter windows that you say aren't, what does ERL call them...
Come up with that answer idiot?
#44
You are the one to correct me saying that they are lifter access, like i am incorrect about the 5th bolt hole access.
Again, where is the 5th bolt hole and how do you access it.
I have lost interest in this thread, trying to discuss a particular subject with someone with no logic and reasoning doesn't do it for me.
#46
Guess i must be the rare case where i can honestly say good riddance had one engine built by ERL. A 434ci dry sleeve for a G8. Engine was fully assembled by erl not just a short block was put in the car and the valvetrain was so noisy they shut it down it would also idle smoothly at 550rpm with a 237/247 cam. Long story short the pushrods they put in it were WAY and i mean WAY short over 125 thou. They did replace them on the dyno. Then after it was tuned we found out the thing really didnt carry good oil pressure when it was hot. The clearances in it werent good for what they knew the engine was going to be used for. A street performance build. Anyway they never made it right i got basically the run around. Oh also took them about 4 months longer than i was told to get the engine. It never laid down the power it should have either. Ended up taking it back out tearing it down and redoing it. Picked up oil pressure as well as about 75hp.
#47
Location: Grew up in Charleston, SC live in Moncure, NC
What timeframe are you talking about here? When did this occur?
#53
^^^^^^^^I like this idea. You have all the parts. Go over with fine-tooth comb...
