My High Elavation 416 Build
Tell him MSD is starting to mold their coils in black now, to dissipate heat better. He might buy it, you never know! Unless he reads this forum....
High Altitude
Hi, you will do well with this C.R. though it would help to know your Intake Duration.
As you know, I have stated a MUCH LARGER Intake Lobe is great for your BARO at 5K-7K feet.
Your BARO will be 65-70 KPA thus multiply the C.R. by that (104 KPA/65KPA ratio)
You will get the correct C.R. for the Altitude Compensation.
Lance
Lance
Lance
Lance
In your other post, everyone figured your compression at 11.4. What has changed to get you to 12.4? You said your builder was going to use a .040 head gasket instead of .051 but that won't make a full point jump in compression. Are you still using -3cc for your piston volume in your calculation?
#32
The original cam was a 235/250 .621/595 116+5 so the new one is just a little different.
Also going with Johnson lifters 2110r instead of the LS7s this time.
Had stock LS3 823 heads and stock intake with NW 92 throttle body.
Original setup put down 501/473 to the wheels through 6 speed manual.
#33
Cam Design at 8000 feet
Hi, your 236/248 may not be the best for you 8K foot operational area.
Lets start with the exhaust, the BARO is ONLY 2/3 pressure at 8K altitude.
The result is a LOWER exhaust pipe pressure, GOOD for more flow.
Thus LESS exhaust duration will work better as the altitude is increased.
Next is the same 2/3 BARO in the Intake Port with result of a NEED for MORE intake duration.
I do not know ALL the operating conditions you require for the "spec" of a camshaft.
SO JUST an EXAMPLE : 242/242 .627"/.557" L/C of ??? provided with more use information such as MAX RPM, manifold design, etc.
Lance
Lance
#34
Lance, I never seen no one run s a single pattern camshaft on a LS3 head period.. Never.
#35
Lance
Lance
#36
Car will be used mostly around 5800, to 4800' elevation. We do live at 7000'. Snowing as I right this lol. Also I pick up the short block and the most CR we are going to get is 12.26:1 with the 64 cc heads and 040 gaskets. Max rpm is at 6600 and intake is a Fast 102 with a ported 90 mm TB.
#37
Camshaft L/C
Hi, OK 6600 RPM, mostly racing ?, will see a Lobe Center of 109* with timing at Split Overlap.
This will Idle Rough, is this the use ?
Do you Day Drive OR More Track ?
Lance
Lance
