Mild "Stealth Cam" Recommendations For Chevy SS Sedan (LS3)
The following users liked this post:
Blk_Ws6 (08-28-2023)
#62
Which is the 2nd Cam Motion cam? The Titan 1?
"This cam profile features PGN352 custom lobes ground under license by Cam Motion on both intake and exhaust. These .352” lift lobes are designed for long spring life and quiet operation with stock ratio rockers and offer outstanding valvetrain stability with high ratio rockers. The PGN352 lobes will out-power Comp XE-R, LSL, LSR, LSK, and XFI hydraulic roller lobes while making considerably less valvetrain noise. The cam core utilizes polished 8620 grade chrome moly steel, which allows the cam to wear longer than the mild 5150 steel used by so many competitors.
Static/Dynamic compression with new cam: 10.7:1 SCR, 8.37:1 DCR.
Recommended valve springs: Brian Tooley Racing .660” duals with Ti retainers.
Recommended pushrod length: 7.400” 5/16” chrome moly but measure to be sure."
You think the Pat G cam would make more power than the Titan 1?
#63
I wouldn't worry about the difference between them too much. I doubt its' much. Just pic one.
I'd personaaly go with PatG spec'd cam. The CamMotion cam I was referring to earlier is the Torque Titan. http://store.cammotion.com/torque-titan-ls-camshaft
#64
I wouldn't worry about the difference between them too much. I doubt its' much. Just pic on.
That's probably what I'll end up doing. That and a RCR ported intake manifold.
#65
While we're waiting for a Pat G recommendation, just for conversations sake, which cam between these 2 should theoretically make the most power? And which would be the most "stealth" like?
Cam 1: Torque Titan 218/226 .595"/.587" 116 LSA
Cam 2: Livernois 1C 218/229 .600"/.600" 117.5 LSA
Back to square 1 it seems. If the Pat G spec-ed cam would make LESS power than the Livernois 1C cam, but they're both "stealthy" wouldn't that make the 1C the better choice between the 2?
Would this make any more power than the Pat G (218/224 .598"/.598" 115 LSA +3) and the Livernois 1C? (218/229 .600"/.600" 117.5 LSA)?
http://store.cammotion.com/titan-1-ls3-camshaft
This is a 217/225 .595"/.587" 114 LSA. At -7 degrees overlap, it should be fairly tame sounding, no?
As far as the Titan 1 vs the Torque Titan, they are really more different than their durations might imply. The Titan 1 has a 109 degree intake centerline and -4 degrees overlap @.050" of lift where the Torque Titan has a 113 degree intake centerline and -10 degrees overlap @.050" lift. This means the Torque Titan will idle smoother and extend the RPM range further than the Titan I. For a stock stall converter, I highly recommend the Torque Titan.
#66
This one right here
The Torque Titan is right at -10 overlap, like you said. Would the Torque Titan outpower the Livernois 1C or is it about the same?
#67
Bigger isnt always better. I done seen Pat G swap a bigger cam out a motor install a smaller cam and make more power. Pat G reminds me of Paul Pierce..... he's the TRUTH!!
#68
I'm confused, I thought the Titan 1 had a -7 degrees of overlap and an intake centerline of 112 degrees. The LSA is listed as 114. Are there different Titan 1 cams?
This one right here
This one right here
#69
Good catch! I had looked at the Titan 1 LS1 instead of the Titan 1 LS3. Yes the Titan 1 LS3 has -7 degrees of overlap. I still prefer the Torque Titan for your application, but you could run the Titan 1 LS3 with a stock torque converter if you wanted. As for the Livernois cam, I cannot speak to its capabilities. However, if the specs are similar, the performance will be similar. With that said, many of our competitors use lobes that can be noisy. Noisy valvetrain can drive you crazy if you get annoyed by such things.
Thanks for the info!
#70
#71
It is actually a pretty new grind for us. We have a few people out there with them that love them, but no videos yet. The boss has one in his daily Vette and he loves it. I do need some customer videos for it though. So, if install this camshaft and share a video idle clip and/or a dyno shoot, I will send you a free Cam Motion shirt.
#72
It would be appreciated if you could post a dyno chart or graph on the Torque Titan. Sounds like a great LS3 cam! With proper springs of course....
#73
Agreed! Does your boss have a dynograph of his Vette with this cam?
#74
Old School Heavy
I'm dying to see a video. What sort of gains did your boss see in his LS3 vette with this cam? As long as it gains at least as much as the Livernois 1C, I'll give it a shot and I'll post plenty of videos.
#75
#76
Got a feeling there is a LOT happening under the curve with the Torque Titan...
#77
Because it ain't the peak HP that makes the difference with this cam.
KW
