Cam swap - Lifter doesn't want to stay "up" for removal
I am ready to remove the cam on my 2011 5.3. Heads and intake are still on so I want to make sure the lifters stay in the up position. I installed a 24" 5/16" wood dowel into the front oil passages of each lifter bank. It went in snug on either side. When I rotate the cam by hand......all the lifters stay up but 1 on #6 cyl. The push rod sinks down slightly when the cam rotates past the top of the lobe. Is this OK? Or am I going to lose the lifter when the cam comes out??
Thanks for the help!
Far from a dumb question.... But kinda get creative, tape it up, tape a **** at the end so it does not slip threw. If it actually has a pocket bracket just bend the tab at a 90 degree angle ect.
