What is the verdict for mild cam in a L92
I'm not asking for much, just a semi-smooth-smooth idle mild cam in a L92 with VVT but no AFM/DOD. I was looking stage 2 rated cams at http://store.cammotion.com/catalog/p...b952e1901da4c8 and http://www.texas-speed.com/p-5330-te...0-112-lsa.aspx
My goal is a nice cruiser made from my 70 Nova. Not looking for in-your-face presentation, but a performer more akin to a cop car. What do y'all think for a good cam? Thanks.
LS1Tech Premium Sponsor
Id go with the tsp one, make sure to install a high quality oil pump like the melling 10295, and change the filter below the valley cover in the back. Whichever one you get youll need the vvt actuator limiter also. Tsp has those and they also have the info for the mandatory changes to a few vvt tables youll have to do.
Thanks for the reply. Indeed, I have talked to the kind sir at TSP about the limiter and I need to verify which phaser I have. He advised I may need a different phaser to go with that cam, all depending on what came stock with this motor. And, gotcha covered on the oil pump as I am going with a higher volume, quality pump. In fact, the Melling is on my shopping list from OReillys (veteran discount) and I'll verify that part number. It's nice to get a little boost of confidence when a more seasoned vet guides me into fishing holes I've been scouting. Thanks for the tips.
I'd PM Clint , -TheBandit_ and ask him his thoughts about his TSP VVT2 cam in his 6.0L 70 Nova. You may not need or want the truck version. He has plenty of videos showing how his car idles and goes with this cam. https://ls1tech.com/forums/conversio...6-0vvt-61.html
The cam would be slightly smaller given your slight increase in CID.
@tech@WS6store - Thank you, again, for the tip. I was eyeballing the Melling 10355? It purports to have the 33% higher volume and "adjustable pressure" increase/decrease with a spring swap. It was also in the HP category but if it's not known and trusted, I'm not deep pocketed enough to be a beta tester and risk losing a big investment.
I just want to be clear about the oil pump issue and concerns. It's clear that higher pressure is better, but is there a problem with also having higher volume? And when you think about it, if you push a 3 gallons of water through a 1/2" hose in 10 seconds and then push 4 gallons through the same hose in the same 10 seconds, won't you have increased pressure with the higher volume? I'm no expert and I don't want to come off as arrogant, but I'd just like to know so I can start fitting pieces of knowledge together on my own to realize the sense and logic in this. Thanks.
Moderator
http://www.compcams.com/Base/pdf/156...189%20core.pdf
I presumed there is another spring because of this comment on the pump's features, "Adjustable Pressure With Optional Relief Spring." OK, so the argument for higher volume is supported by the need to lubricate more components? That seem logical. I'm staying simple so that's cool.
~Steven
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com • ☎ 225-926-6110 • Like Us On Facebook!
I believe that any oil pan that you'd be using on your Nova would have either a 5 or 6 qt capacity, so.....one of the best reasons for NOT going with the high volume pump.
Also.....I would call CamMotion........but hell, that's just me.
KW
OK, let's clear that air just a bit. I went with the Holley oil pan #302-2 which is rated as 5.7 qts in the sump and 6.2 qts overall in the system. That was selected to match the Hooker Trans mount/crossmember supporting a 4L60E. So, yes, it is not a higher capacity solution and the point is well taken. Thanks, appreciate the feedback. Indeed, Cammotion is still under consideration.
@Steven - The initial plan is to keep the VVT and go with a single. I might, later, consider tuning software to have multiple tunes, one for daily driving in the DFW Metro and seek a little more boost at lower RPMs and another for road trips with more boost at higher RPM. We're still hemming/hawing over the torque converter setting for the tranny and we also have the rear-end to consider. At some point, the original rear-end that came with the original 307/TH350 was replaced with a 12-bolt style, and we'll soon look at the gear ratio. The objective for me has always been having a cruiser that will give me highway power at higher speeds. If you've ever traversed Interstate 35 between Dallas and San Antonio and get boxed in by sloppy drivers, you know the frustrations when your in your stock 2500HD Silverado. I want quick getaways on the highways.
~Steven
__________________
Honestly you be better off with a std pattern non vvt cam. And alot less hassle.
A simple stg1 225/236 tsp cam. no worrying about which phaser or tables to change etc etc.
Itll give you everything you are looking for and let you cruise with a 3.42 or 3.7 no problem.
http://www.texas-speed.com/p-5760-new-texas-speed-stage-1-ls3-225236-629615-camshaft.aspx
Just needs a 3bolt 4x cam gear and ls3 front cover (which comes with gasket and seal and bolts, sensor and harness)
If going turbo youd want the 10296 MAYBE. a single isnt much of a diff in oil volume needed but twins would be. depends on your size also and length of line. an oil cooler would also be highly recommended as well for turbo.
Just a straight forward simple question with regards to running a high volume oil pump on any engine:
How can you PUMP more oil if you don't HAVE more oil ???
There are plenty of engines/combinations that can benefit from a high volume pump; however, unless your pan HOLDS more quantity I most certainly wouldn't try pumping more quantity.
Sucking the pan dry ruins the main bearings in short order.
IMO from building a few turbo combos, that's not necessarily a reason to mandate a high volume pump. For one; a nicely ported STD volume will feed just fine and second; you then won't need restriction pills to prevent blowing out the turbo seals like what can happen with an HV/HP pump
