Which heads have a better discharge coefficient? TFS 235's or mast small bore ls3's
This sounds like a job for....... TONY MAMO!
OK, enough screwing around. Will SOMEBODY come and help our bud here with some answers??
Moderator
http://www.wallaceracing.com/discharge-coef.php
Same basic heads! If your were to place them on the same engine what you"d say would be the difference? In terms of Hp/ Tq? One has a 11 degree intake valve angle while the other a Nos exhaust port. ? of Hp and Tq or how they'd each preform.. or as you asked:
Ask which name sounds better. And that's your answer. Very similar numbers and performance. That's even with one being a cathedral and the other being a rectangular style head.
Moderator
Received 1,835 Likes
Not so sure. The mast heads are flowing on a 3.9" plate what the tfs are flowing on a 4.125" plate. That's probably your answer right there.
You can say that but ER racing Ls7 heads were basically touching the bore on the exhaust side. 4.065 bore Hp was still made. I understand the logic and facts yet Numbers are basically the same. So what does this say. They say Ls3 heads are so shrouded on a bore of under 4.060 like 4.005. Why I ask do the still make hp.
