Did I crossover to the dark side? (Square port porn inside)
#184
That’s my 2” kooks with 3.5” collectors to the kooks y pipe that has a 4” outlet. That’s just open y pipe in the video. I plan on putting my 4” dynomax bullet muffler on it to run some street shootout stuff. I may wventually just put some 3.5” vibrant muffles off the collectors tho lol
#188
The holes look a little egged and beat up. I'm using a lokar s-1034 universal cable end on mine. Looks like you'll need a longer bolt than mine to connect your return springs. Once you search that you should be able to find one you can use.
#194
Moderator
Received 1,852 Likes
Originally Posted by big hammer
It’s not a street car unless it has a plastic intake!
#195
Universal Lokar throttle cable for carb type intake will work. Thats what I used on mine. You just have to improvise and figure out something about those bolt holes on the throttle body. You may be able to replace that part from Wilson. Great build, can't wait to see it run!
#196
PS what valve covers are you running? My Holley's don't seem to fit right
#198
They are the proforms. I like them but they don’t work well with my Crowers. I really want to find a nice set that don’t have coil pack bosses and have some -10 fittings on them that work with these heads. They have such a tall valve cover rail it’s crazy.
