Darton sleeved LS2 454 vs RHS block 454
I might "be your huckleberry" and order one. There will always be another build. Cheaper than going sleeved GM, after you figure in billet main caps...
Well there you go. This is exceptional value...if it actually works.
When I emailed the guy at Concept the sleeves were 5.87 in length in the key areas which is similar to the RHS one. He also indicated that a 4.185 bore the steel sleeve is .067 thick and that there was still around .250 aluminum behind it in the non-siamesed areas. They now offer tall decks.
