LS3 and L99 Easiest way to tell them apart??
What would be the quickest way to tell the LS3 from the L99 looking at them. What should i look for? Say i am looking at a block with heads with the valve covers off?
Look at the valley cover. If it's ribbed, it had DOD. If its smooth, its a LS3. You can also look at the timing cover. If the timing has a protrusion (Kinda loooks like a hockey puck and wires coming out of it ) where the cam would go, its a L99. Thats the cam phaser. If the timing covor is flat (upper half) its a LS3
I am looking at a longblock to buy and just wanted to make 100% sure it was the LS3 and I am pretty certain it sure is. I dont want the L99 for the vvt. Does anyone have a pic of the L99 with the water pump off showing the cover?
Hopefully you are looking at an LS3, as converting an L99 to LS3 status can be a little costly. L99's can be cheaper than LS3's but the difference is usually not enough to cover the conversion cost.
NICE! Take it home and feed it well!
2 year bump using search function.
Is there a way to tell if you have a LS3 cam or l99 cam? A buddy of mine has to put a stock cam back in his 12' Vette and remove his comp cam. He picked up a cam off Ebay that was from a 10'-15' SS Camaro. We put that cam in without looking at the part # and now curious if he has the correct cam.
I think he is ok since the other cam came with a single normal style cam bolt, and the front of the cam has a single normal hole unlike the l99 front that looks different.
Thanks
Thanks
Thanks
Thanks
Thanks
