4.065 + 0.20 (4.085) File Fit Rings? 1.5, 1.5, 2.5
Hey All,
I've been searching the web for a couple of days for a set of file fit rings for my pistons. They are 1.5mm top, 1.5mm 2nd and 2.5mm oil control rings. For some reason I can't find anyone that does a set of file fit rings (the drop in + 0.020 rings from Hastings had ring gaps > 0.023 which is too much for the intended street use). The motor is an LS3 and I have +0.020 pistons to match the bore.
Any leads would be greatly appreciated.
Cheers!
Cheers!
My searching doesn’t show anything either. What piston are you running?
Thank you, I can’t remember the piston brand.
I checked out the Mahle rings but according to Summit’s site they aren’t file fit. Sometimes that means they are pre-gapped and that’s where I’ve run into issues with the Hastings rings. The “pre-gapped” gap meant the gaps were too big for my application.
Do you know if this is the case with that Mahle part?
