Cathedral vs Ls3 test
Old Oct 30, 2018 | 07:56 AM
  #121
HioSSilver's Avatar
Yea a ls3 intake on that combo is a no no unless it's a truck......oh wait
When you changed to the fast did you change to a 102mm tb also?
Old Oct 30, 2018 | 08:35 AM
  #122
Darth_V8r's Avatar
Moderator
My god, square ports AND midlength runners? Do you even have enough torque to cruise down the highway???
Old Oct 30, 2018 | 09:14 AM
  #123
BigDaddy97's Avatar
I had the 102 on the LS3 intake and the fast intake.
Old Oct 30, 2018 | 09:18 AM
  #124
BigDaddy97's Avatar
Bahaha.....cutting a 1.36 sixty foot while leaving off the footbrake at only 1400.......I got foot pounds a plenty
Old Oct 30, 2018 | 10:05 AM
  #125
Darth_V8r's Avatar
Moderator
Yeah I personally believe a big cube motor will make torque whether you want it to or not. Just build for power.
Old Oct 30, 2018 | 10:07 AM
  #126
HioSSilver's Avatar
Good.....is your fast ported?
lol.....some here would believe that was impossible
Old Oct 30, 2018 | 12:54 PM
  #127
KCS's Avatar
KCS
Moderator
More cubes certainly helps.
Old Oct 30, 2018 | 01:08 PM
  #128
Tuskyz28's Avatar
The head with the larger intake runner is always the better head.... point blank period.
Old Oct 30, 2018 | 01:45 PM
  #129
spanks13's Avatar
The head with the best approach into the chamber is the better head.
Old Oct 30, 2018 | 02:03 PM
  #130
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
How about GM CNC LS3 (276 CCs) VS AFR (260 CC),TFS (255 CC), or MAST Mid Bore (255 CC) LS3 Heads?
Just to name 3.
Old Oct 30, 2018 | 02:16 PM
  #131
Originally Posted by NAVYBLUE210
………..AFR (260 CC),TFS (255 CC), or MAST Mid Bore (255 CC) LS3 Heads?
Just to name 3.
And these are aftermarket heads. I've seen where the TSP(PRC) CNC LS3 head at about 269 CC out flows the GM CNC. It's the path, not the volume....
Old Oct 30, 2018 | 02:36 PM
  #132
Whoa kimosabe. Better head for what exactly?
Old Oct 30, 2018 | 02:44 PM
  #133
KCS's Avatar
KCS
Moderator
I hope you’re joking.
Old Oct 30, 2018 | 03:23 PM
  #134
BigDaddy97's Avatar
No sir
Trust me it's very possible. The fast is not ported.
Old Oct 30, 2018 | 04:10 PM
  #135
Tuskyz28's Avatar
I can send my LS3 heads to Frankenstein for the 1.5 program to make them 288cc on the intake runner and it will make more power than any head in this thread. Y'all guys just a bunch of haters. Always hating cause i know what im talking about.
Old Oct 30, 2018 | 04:44 PM
  #136
No Hate. "Just Keeping it Real!" when you get out ahead of your skis.
A little humility goes a Long way!
Old Nov 1, 2018 | 04:33 PM
  #137
big hammer's Avatar
Thanks Navy and to answer your questions, this stroker gave up very very little on the bottom end but now peaks at 6800 and pulls to 7200 when i took your advice and switched to the fast mid runner. The previous intake was a radius mod LS3 which is a fine piece for some applications but ran out of air at only 5800 on my 421. I was only running mid 10.80's with the LS3 intake and off the shelf stroker cam. I switched to the mid runner intake and a custom cam motion cam and went 10.42. My #1 problem now is getting all this power to the ground which i suspect the custom powerglide will solve, because my starting line ratio is ridiculous as it is.
thats interesting. I have a buddy with a 416 with ported heads and a big Cam and it’s shitting the bed after 5800 as well. Has stock ls3 intake
Old Nov 1, 2018 | 05:19 PM
  #138
BigDaddy97's Avatar
I think the piston speed of my stroker is just to high for the LS3 intake to keep up with the air demands.
Old Nov 1, 2018 | 07:01 PM
  #139
MuhThugga's Avatar
According to the interwebz, it should be about on-par with an Olds 350 diesel.
Old Nov 1, 2018 | 07:59 PM
  #140
big hammer's Avatar
agreed
