High RPM wet sump?? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
High RPM wet sump??
Old 12-27-2018, 12:03 PM
62nalide's Avatar
Default High RPM wet sump??
Not sure what oil pump to run on a twin turbo 427 that has plans on seeing 7700-8000rpms. Would like to stay wet sump if possible or max RPMs on a wet sump setup.
Have some suggesting the Melling 10355
62nalide is offline
Old 12-27-2018, 01:06 PM
You can do almost anything for a short period of time. Are your high rpm pulls going to be limited to quarter mile or less, or are you going to do longer duration runs like half mile or full mile?
Are your turbos fed by engine oil pressure?
Oil cooler?
External wet sump is likely going to be your best option, and internal wetsump might work if you only plan on doing short bursts of high rpm.
spanks13 is offline
Old 12-27-2018, 03:20 PM
LS1Tech Sponsor
Summitracing's Avatar
__________________
800-230-3030
www.SummitRacing.com
Summitracing is online now
Old 12-27-2018, 04:30 PM
62nalide's Avatar
Oil cooler?
Main Focus will be 1/8 mile and only plan on seeing 75-7700rpms and once I hit the 1/4 mile I plan on seeing 8k max. Track use only won't see much street.
62nalide is offline
Old 12-31-2018, 10:31 AM
lstvr's Avatar
I see track days and Qtr miles, Iíve ran at 200+mph on a 2 mile runway, Iíve got a trapdoor baffle for the corners, no appreciable wear on any bearings on my recent rebuild, Iíve an oil cooler and rev to 7500 if I need to.
lstvr is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
