Need help after head gasket replacement!
Just replaced head gaskets on my LS2/3 frankenstein. After attempts to start..(worked out kinks with fuel pressure), the pulleys sound as if they are trying to bind and are turning slower and slower. Oil pressure is good, fuel is now good. Any ideas? Im trying to post a short video of the sound..
Thanks
Thanks
Thanks
Thanks
It looks like it's locking up and the belt is squealing. Prior to installing pulley's, alternator, power steering pump, a/c compressor did you make sure all of those components spun freely? Also did you pull all the spark plugs out and turned the engine over by hand to make sure it's not binding up?
Mystery solved.
