GPI 281cc Heads Cam LS3 what do you think it will make
#82
For all the this car will be lazy and you cant street drive it
#85
#88
Very good question
I'm running the TR6060 ZR1 spec transmission with the MH3 gear set. Originally, I was going to run some spray on my original build so I wanted the stronger 1st gear for torque capacity. I'm now a big stroker N/A which we are also expecting big torque numbers.
Forgive me for doing a copy and paste from my other threads on my choice.... that thread is located here https://www.corvetteforum.com/forums...badaz06-3.html
It all depends what what you goal or end game is.....
3.90's ended up being the better compromise for my setup, given I run 1/4, 1/2 and 1 mile competitions, as well and HPDE. I install shorter or taller diameter tires to adjust the final drive accordingly, based on the events I'm running.
I would post the calculator I used to look at the results that helped me make my decision but the site is no longer available
This one looks to be good as well..... http://www.gtsparkplugs.com/GearCalc.html
Here's two comparisons I did, first is 3.90 vs 4.10 with a 25.5" 315/35/17 Hoosier Drag radial....... MH3 tansmission, 7400 RPM shift
Same setup, but a move up to 27" drag tire.....
And this is with my factory street tire...335/25/20
#89
#94
#96
https://www.hotrod.com/articles/20-l...ifolds-tested/
#97
This was testing on LS1 intakes, but maybe the port lengths are consistent ?
#98
Skeered low pro's have about a 3in runner...ls7 i think, there's not to much difference. Go to the holley site, get to the intake wanted hit instructions, all lengths for all holley intake used for a particular intake. Hi ram instructions list :ls1-3-7 runner lengths. Same with the low pro.
