LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   LS7 crankshaft oil plug depth (https://ls1tech.com/forums/generation-iv-internal-engine/1916625-ls7-crankshaft-oil-plug-depth.html)
QwkTrip 03-10-2019 08:51 PM
What is the correct install depth of the crankshaft oil plug in an LS7 crankshaft? I think mine has been knocked backwards.
QwkTrip 03-10-2019 09:10 PM
For reference, my plug is 2.0" from the outer most part of the hub pilot, and 1.7" from the flywheel mounting face of the crankshaft.
QwkTrip 03-11-2019 09:09 PM
From what I can tell, the plug just sees oil splash and the galley is not pressurized; so if the plug is seated firm and square then don't worry about it.
Che70velle 03-11-2019 09:14 PM
Qwk, are you talking about the glued in plug, in the center of the crank, behind the pilot bearing?
if so, you are correct. It does not see oil pressure, but needs to be sealed off for crankcase pressure. I don’t think there is a dedicated dimension depth for that plug. I’ve seen guys use just silicon to fill that hole...if I’m talking about the same plug you are referring to.
QwkTrip 03-11-2019 09:57 PM
Yep, that's the plug. I didn't realize it was glued in place. What kind of glue do they use?
Che70velle 03-12-2019 03:42 PM
I don’t know what is used to seal that plug. RTV? Silicone? My Callies crank looks like clear silicone.
QwkTrip 03-13-2019 06:49 PM
Thanks, bud! Seems you always step in to help me and I appreciate that! :)
© 2024 MH Sub I, LLC dba Internet Brands
