help me find sleeves for my 418
I am building a 418 stroker iron block and i need good sleeves i will go about 1000 HP
any suggestion where to find a good sleeves go up to 1000HP
There is only one brand worth looking at - Darton. https://dartonsleeves.com/
They're available from all over - likely even on e-bay if you want to get your local machinist to fit them (make sure they have a good reputation for them).
I'm sure a few vendors here can help, I know Texas Speed can supply and fit as does RED in CA. If you went all out and did the premium Darton MID wet sleeves, then RED has an excellent reputation on making those work. MID require a bit more precision and care, not sure who else has a great reputation for success on those, but the dry sleeves are a lot easier and cheaper..
B it don't add up or make any sense what's being asked. Factory iron lq4 is good to 1000 just not a 418... but 402 / 408. To re sleeve a iron block which will crack near the cam on the front side of the block. Price is $3000. Dart or Lsx block?
For press in sleeves.... Why? As is the lq is good 4 1000+hp.
Same thought expressed .....steve @ RED gave me the answer i gave him yrs ago. Big bore lq4....to have to dry sleeve it, as you said is point less find another block.
http://www.raceenginedevelopment.com/blocks/gm-lq9-mid/
thanks for the information, i changed my mind i will use aluminum block what do you think ?
i already have Diamond piston part: 11578 what if i use 6.0L aluminum block with Factory sleeves ? machen it a little pit to fit my piston
my piston bore is 4.065"
and 6.0L bore is 4.00"
any idea ?
any idea ?
no special thing about iron block i was thinking it is more stronger thin aluminum
but it seams to me iron block is heavy for my car and it will effect to my suspension system i use so i will use aluminum block
Do not pass go.....do not collect $200 dollars LOL
I'm going to save you a bunch of time and/or frustration, and point you directly to the source for what you want. .....Horse Power Research for the win !!!!
https://horsepower-research.com/coll...s-engine-block
any idea ?
any idea ?
You need either an LS3, LSA, or LS9 block, all which use a 4.065" bore.
