Which quench would you choose .035 or .041? Also, is quench set cold or warm?
#41
Moderator
Received 1,835 Likes
No I did not
#43
Moderator
Stock.
#45
Moderator
I think that is also when I went LLSR. That is a good point.
#46
If quench is tight because of a need or want ...
Fly cutting for pvc is nothing major. I've been considering .035 and steel rod and get the valve clearances for min to pistons which is I think around 80 thousandths . Sitting out the hole at min 5 thousandths 8 would be better. Rpm range of 7500 1st go around.
#49
Had to get the correct crank scrapper...342f without the windage tray, moroso came with one. Called it in and Jim got it ordered... invoice sent to my email 199.oo + shipping. Dropping off short block maybe this weekend...if I have time, on to Tennessee Saturday. But definitely once I return.. if a # not gotten I'll burn it.. I got real faith.
#50
#52
Smokey might consider not smoking ganja while posting.
#54
Just will be talking about stuff already purchased....so no thinking or guessing ...or opinions.. not in a bad way.. want to more than some larger higher dollar builds for sure. That's why if not gotten .... Burned! Can keep that money for other work or parts and keep it in the bank. If I'm looking at low 700 yeah I'll burn it ...find another hobby to waste money on.
#56
#58
