Vengeance Racing Annihilator cam in ls3? Changing my set up in a month or so from Trickflow 255s to try a set of the Frankenstein f310s. Changing cams in the process and was wondering if anyone has ever used the Annihilator cam in a ls3 or is this more of a ls7 cam? |
Originally Posted by andy-lswon
(Post 20106237)
Changing my set up in a month or so from Trickflow 255s to try a set of the Frankenstein f310s. Changing cams in the process and was wondering if anyone has ever used the Annihilator cam in a ls3 or is this more of a ls7 cam? However it may not fit on a 239 intake duration with LS3 heads. This is more suitable for a 400+ stroker engine or an LS7. With 19 degrees of overlap it would not drive well in an LS3 if it would fit. You would need more compression but you won't be able to mill your heads unless you change your pistons otherwise you won't have enough PTV clearance. Not sure about those Frankenstein heads though. Tell us your combo |
Originally Posted by bortous
(Post 20106272)
The annihilator camshaft is more like a max effort LS3. However it may not fit on a 239 intake duration with LS3 heads. This is more suitable for a 400+ stroker engine or an LS7. With 19 degrees of overlap it would not drive well in an LS3 if it would fit. You would need more compression but you won't be able to mill your heads unless you change your pistons otherwise you won't have enough PTV clearance. Not sure about those Frankenstein heads though. Tell us your combo |
(Post 20106367)
Just a stock ls3 other than the heads and cam. Those Frankenstein heads have 10 degree valves I knew it wouldn't work with stock ls3 heads but wasnt sure about those ones. Probably just gonna go with the kaotik |
(Post 20106369)
what are the specs of that katoik cam you are looking at? |
(Post 20106532)
235/243 |
(Post 20106538)
and the LSA? |
(Post 20106539)
113 I believe It's a good spec for an ls3. IVC point and EVO point is good for power everywhere except it may fall short a bit in the top end. What is your goal with this build? |
It's an auto car so I'm hoping to put down around 500ish to the tires |
Ok. I think you will get close to that power figure with such a camshaft size. Having higher compression will also help. It's almost identical to my last cam 236/244 114 LSA. But this was in a stroker engine. I made 505rwhp with it. I reckon it should rev to 6500rpm without an issue. Make sure it's installed 3 degrees advanced on a 110 ICL |
(Post 20106543)
I worked out the specs. It's a good spec for an ls3. IVC point and EVO point is good for power everywhere except it may fall short a bit in the top end. What is your goal with this build? |
(Post 20106549)
Current set up made 478 with the trickflow 255s and 232/244 cam. I was honestly disappointed thinking the trickflows would make more |
(Post 20106550)
Were the TFS heads cathedrals? |
Oh really? You should've just stayed with your stock heads and cnc ported them. The stock heads are already really good. |
What chassis are you working with? |
Originally Posted by lazerlemonta
(Post 20106630)
(Post 20106630)
What chassis are you working with? I am in Australia. |
(Post 20106237)
Changing my set up in a month or so from Trickflow 255s to try a set of the Frankenstein f310s. Changing cams in the process and was wondering if anyone has ever used the Annihilator cam in a ls3 or is this more of a ls7 cam? https://vengeanceracing.net/2006-z06...624-113-2.html |
I would probably use Brian Tooley's 233/250 113 LSA +5 camshaft. Will not hit pistons with unmilled heads and you should get 500rwhp+ |
What intake are you going to use? |
© 2024 MH Sub I, LLC dba Internet Brands
