Main cap side bolts - Does it matter what kind you use?
Summit Racing and Lsxcelleration both sell OEM main bolt kits. But I have found that it is actually cheaper to buy the OEM bolts individually rather than either of these sets. It is even CHEAPER if you buy two five packs of ARP M8x1.25 - 25 bolts rather than the OEM bolts. Since these would just be torqued to the normal 18ft-lb as stock, is there a problem with using these in place of the stock bolts? Also, would it be better if aluminum crush washers are used with these bolts rather than the usual RTV?
The following users liked this post:
rkupon1 (02-21-2021)
I use the ARP bolts, and your right, they are actually very affordable. I use ARP everywhere and buy them individually from Summit. I torque them to 22ft lbs. without issue and use a dab of grey RTV under the bolt heads before install. Works great. Never tried the aluminum crush washers, so I can’t comment.
Darn good question as I've got a paid 4 new = Got used: ARP main Stud set, missing side bolts.
No. I’m using ARP across the board, along with the associated machine work when the builds call for ARP hardware. BUT, the side bolts will not affect what the inside fasteners are doing and torque values won’t change inside, therefore NOT requiring a line hone. The side bolts are there for lateral movement only, which is why they are so small.
Corona (02-22-2021)
I know that Honda does this for the cross bolts on the V6 in my Accord. So I figured it might work on an LS as well, especially since there is apparently some connection between the design of these two engine families.
Unless you have caps that don't fit correctly, the ARP side bolts will not distort the cap housing as Che70velle mentioned with factory main bolts.
I have measured them myself with and with out side bolts and see virtually no change that I can measure. I did this to verify what the machine shop I use was telling me regarding their findings.
Jimbo1367 (02-23-2021)
The side bolts put very little force on the caps. They're too small to significantly distort any of the metal.
The reason they can be so effective while being so small is, the forces on them are in shear; not bending or pulling, like the "main" main bolts. Those, the forces applied to them are in orientations that the bolts and the parts are inherently not as strong, therefore have to be bigger, tighter, etc.
People pull them all the time and put them back in, often replacing them, just to assure no leaks.
Matt is probably right... ARP's disclaimer is just that, a disclaimer. CYA. Not the same thing as a fact-based need.
G Atsma (02-23-2021)
This is DEFINITELY true when using the full ARP stud kit. But in this case, only the side bolts are being replaced by ARP. The main bolts are still OEM. With the side bolts, the same type of fastener is being used compared to stock (bolt vs stud), the length is the same (25mm), and the bolts are being torqued to factory spec (18ft-lb). This should NOT distort the caps.
