Spring Mass
Moderator
Received 1,852 Likes
Spring Mass
How many are using the mass of the spring when calculating spring specs?
Here's an analogy. You put more fuel in an airplane, then you need to put more-er fuel in the plane to account for the extra weight.
The following 3 users liked this post by Darth_V8r:
When you calculate the sprung/unsprung weight in suspension tuning due to the mass of the suspension springs, you only use half the mass... the part of the spring that touches the car doesn't move in respect to the car. The part of the spring in contact with the suspension is moving just as much as the suspension is. The part of the spring in the middle is only moving half as much. So on average, it's assumed that half of the mass of the spring is moving.
The same consideration would probably apply to valve springs. The part at the retainer end is seeing full valve motion. The part touching the head isn't moving.
None of this is as interesting or fun as talking about cam selection.
If you want the facts of.... contact
3vperformance
Also YB member, EFI University would be another....
Chris U or Straub, and the FTI guy...
Spintron testing?
Not saying anyone's wrong but your eluding to what a race guy does....in setting up a Race Valve train...
ER as well..
3vperformance
Spintron testing?
ER as well..
The following users liked this post:
DualQuadDave (08-06-2021)
The following 2 users liked this post by KCS:
Corona (08-06-2021), DualQuadDave (08-06-2021)
Joe Hornick racing Valve springs 🤫 is a amazing group who design and Ask springs of PAC aka: custom LSX springs.... They would and should be able to Answer Any question about a valve spring.
Special needs and Answers pertaining to 👍
Ed Curtis of FTI... Duh 🙄
The new Age Lobe Technology is making it so much Easier on springs and valve spring Life = Less spring weight/mass needed
There are "many" comp cams Low Shock lobes...
Hydraulic and Solid Roller when considering a new cam and designing it yourself...
Sorry but if Anyone finds the Entire Low Shock lobes list and it's spec's ... please send them to me...
I've only seen the 3 letter alphabet representing each Particular lobe whether hydraulic or solid...
There's Alot of them 🤫
Free Hp....
Free Hp....
I think "low shock lobes" are the biggest advance in cam tech in 20 years or more...
Corona (08-06-2021)
LST Lobe Families
Hydraulic RollerMGZ, MGH, MBZ, LPM, LSD, XLD & LSO
Endurance Solid Rollers
LGW, LGA, LIH, LHW, LXW, LDW, LKD, LXE
Drag Race Solid Rollers
LMS, LMX, MMO, MMX, OLM, MBW, MST, MJN, MJW, MJO, MDW, MNP, MFP, MTW, MSL, LXC, MSM
G you know I cheated in class...
just read that you gotta get a email with the Lobes sent through Email from Comp Cams...read on YB guy says he has them and how he got them..
G Atsma (08-06-2021)
He (Jonathan) didn't give me a list but we matched my cam with a .420 Low Shock lobe & grind Number...
I'll ask the YB guy also.
For me personally, spring mass isn’t something I consider when setting up heads. My goal is to put enough spring into the setup to effectively control the valve at max rpm, considering all parameters, and nothing more. I don’t mind running Ti retainers on the street, which many here on Tech refuse to do, which helps a little also.
The following 3 users liked this post by Che70velle:
G Atsma, I think the problem is people think that it's ok to run springs/retainers for years and don't consider them a maintenance item, They were never meant to last the life of a street engine. That leads to people saying running them on the street is a bad idea. It's kind of like people saying you shouldn't run a solid lifter on the street, It can be done and be reliable if you maintain them.
The following 3 users liked this post by LLLosingit:
8 yrs doesn't tell the whole story, How it's used and how often makes a huge difference. If it's a daily driver seeing lots of miles then it's a probably a good idea to change spring and retainers well before that. On a serious race engine they life expectancy is counted in hours/laps/passes depending on application and they are changed accordingly.
Ive learnt that with my set up i have to change springs once a yr, retainers get changed with springs. Also i bought a new set of crower solid lifters so that when i change springs i will swap out lifters and send the set i took out for a rebuild, itll save a month of downtime waiting for lifters.
So i shouldnt have a problem with retainers then????
I've learnt that with my set up i have to change springs once a yr, retainers get changed with springs. Also i bought a new set of crower solid lifters so that when i change springs i will swap out lifters and send the set i took out for a rebuild, it'll save a month of downtime waiting for lifters.
So I shouldn't have a problem with retainers then????
