LS427/570 LS7 from GMPP - Experience or Discussion
Old 11-03-2021, 03:29 PM
"I MAID THEESE"
Mavn's Avatar
Originally Posted by kinger
Can you spell out this recipe you speak of on the 416? By the time you add in machine shop labor, parts, I am coming up with 10-12K no matter what. I am only looking at the aluminum blocks no iron in my figures. The LS7 has the intake and oil pan that will fit my swap so that hurts the LS3 too having to buy those parts. The LS7 seems like a screaming deal and I happen to love the idea of Ti bits that is bespoke tech most people would give a left nut for. I wonder what the fail ratio of LS7s are in total. We only see the failures. Any guesses on total number of LS7's made then divide by maybe the 200 failures people have posted?
sure a 416ci shortblock from Thompson is $5100
You need stock LS3 heads $600 used
Stock ls3 intake $200 Amazon
Ls3 rails and injectors $200
Fbody oil pan with pickup tube $160 used
Cam kit - $600
Lifters $200
Amazon LS full gasket kit - $200
416 wirh stock ls3 heads will make 530+ rwhp all day.
Add some misc bullshit
Let's just say 8.5 grand .
Old 11-03-2021, 03:35 PM
fnbadaz06's Avatar
I'm not really up on the LS7 "issues" as new C6Z06 or new 5th Gen Z28 was out of my reach for a long time. Never trusted the maintenance on either of the pre-owned C6Z06's I test drove.
There are a several C6Z06 owners with 100,000+ miles on their LS7's without any issues. I assumed if the LS7 wasn't beat on regularly on a Road Course Track Day it held up as well as other LS engines.
I thought it was when LS7's are constantly pulling the big revs at track days with multiple sessions and lots of laps where the bad things seem to start happening. Like oil consumption goes up way up, like the track dogs using a quart per day. Then the valve guide wear git started.
The general view sounds like LS7's are only reliable for ~30,000 miles of daily driving and not reliable for drag strip or road course use?
Not arguing just asking.
I went over 65,000 miles on my LS7 before the heads were looked at and addressed. It may be just luck of the draw,
Old 11-03-2021, 06:11 PM
grinder11's Avatar
Received 1,186 Likes on 826 Posts
LS1Tech 20 Year Member
Happened to see this when looking at GM Performance Parts etc.Opinions? Experience?
Has the titanium rods, titanium intake valves, cnc'd heads, intake, tb, injectors, coil packs, oil pan mid 12k price. Cam seems a little small but ~500whp is probably a given even with 227/242 cam.
Chevy Performance Parts - LS7 427/570
PART NO. 19421004
LS427/570 Tech Specs
  • Part Number: 19421004
  • Engine Type: LS-Series Small-Block V-8
  • Displacement (cu. in.): 427 (7.0L)
  • Bore x Stroke (in.): 4.125 x 4.000 (101.6 x 92 mm)
  • Block (P/N 12602689): Cast aluminum block with 6-bolt, cross-bolted main caps
  • Crankshaft (P/N 12611649): Forged steel
  • Connecting Rods (P/N 12661677): Forged titanium
  • Pistons: Hypereutectic aluminum
  • Camshaft Type (P/N 19419859): Hydraulic roller
  • Valve Lift (in.): .591 intake/.590 exhaust
  • Camshaft Duration (@.050 in.): 227º intake/242º exhaust
  • Camshaft Lobe Separation Angle: 116º
  • Cylinder Heads: CNC-ported LS7-style ports with 70 cc combustion chambers
  • Valve Size (in.): 2.200 titanium intake, 1.610 sodium-filled exhaust
  • Compression Ratio: 11.0:1
  • Rocker Arms: Investment-cast, roller-bearing trunnion
  • Rocker Arm Ratio: 1.8:1 (offset intake)
  • Recommended Fuel: Premium pump
  • Maximum Recommended RPM: 7000 rpm
  • Balanced: Internal
I disagree about 500whp from 570 crank hp. It might be high 400s. BUT-If GM has deliberately underrated it, like they did with the 505hp version, and its maybe 590@crank, then I agree.....
Old 11-03-2021, 06:18 PM
grinder11's Avatar
A more important consideration would be whether-
A: They have the Ti intakes CrN coating right,
B: They have the Ti rods CrN coating right, and,
​C: They dumped Linimar as the CNC vendor.
Old 11-03-2021, 06:24 PM
grinder11's Avatar
Originally Posted by spanks13
It comes with a 24 month 50k mile warranty. The 24 month timeframe kind of sucks for going in a hotrod cruiser, but they're willing to throw a 50k mile warranty on it.
Why do they recommend 15W/50 is probably the biggest question I have? I've never seen that from an LS engine before, and modern engine trends are to put thinner and thinner oil.
I think this engine is an amazing deal when you consider the parts in it. An ls7 block alone is ~$3900. Yes the LS3 is close on peak performance numbers after a cam, but you have 51 less cubic inches, a cast crank, cast rods, pistons without valve reliefs, and while you might hit the same 480-500whp you'll be way down on average power through the rev range.
Plus it is a mf ls7 which will always be a "poster on the wall" level engine for me. Forged crank, forged Ti rods, titanium intakes, the magic 427 cubic inches. You know you've got one of the baddest factory NA engines ever built.
Swap the cam and throw an msd intake on it and you're at 580 whp easy easy and no other modifications needed. With headers and any other intake you're at 525whp with this thing all day and it would "drive like stock" with that camshaft.
When speaking of that warranty, keep in mind that, AFAIK, the warranty is good ONLY IF the engine is installed at a GM dealer, with the pre-programmed GM ECM......
The following users liked this post:
Jimbo1367 (01-31-2022)
Old 11-03-2021, 08:44 PM
Received 3,696 Likes on 2,249 Posts
LS1Tech 10 Year
Warranty. I laugh every time I see that word here on Tech. Who leaves anything performance oriented alone these days? Serious question. You’ll just end up onboard the GM LS7 lawsuit train, if you expect this to last, if left stock. But you won’t. You’ll get bored with the power and throw an intake and camshaft at it before long. It’s just waaaay to easy to make another 100 hp with the 427 platform.
The following 4 users liked this post by Che70velle:
cino (11-03-2021), G Atsma (11-04-2021), grinder11 (11-29-2021), Rich2342 (03-01-2023)
Old 11-09-2021, 01:18 PM
Moderator
John B's Avatar
It will EASILY make 500 at the wheels! When I ran my bone stock crate motor 505HP rated LS7 in my Monte SS ~15 years ago it laid down 487 RWHP with just headers and full exhaust....I can't see many people swaping in the LS427/5760 and not using full length headers! Case closed!
99 Black Bird T/A (11-09-2021)
Old 11-09-2021, 01:21 PM
Moderator
John B's Avatar
Daily drove my 2011 Z06 for 59K+ miles and it is still going strong today, 100% stock and untouched. When I put the crate motor LS7 in my Monte SS, I daily drove it for for about 20K miles before mods with zero issues.
Old 11-09-2021, 03:26 PM
dAgent's Avatar
So the cam specs are 227/240 116, does anyone know the advance? If not, what do you think it is judging by past GM cams?
Old 11-09-2021, 05:15 PM
01CamaroSSTx's Avatar
Received 1,947 Likes on 1,400 Posts
Stock LS3 intake and heads on a 416 putting down 530 rwhp in what though? I certainly wouldn't see that in my car which has an LSX 427 with Brodix BR7's, LSXr 102, NW 102, 2" KOOKS with their 3" off-road exhaust.
Old 11-27-2021, 09:45 PM
KW Baraka's Avatar
From 0* and +2* advance.....
KW
Old 11-29-2021, 09:03 AM
  #32
grinder11's Avatar
Originally Posted by old motorhead
I'd spend a few bucks on a custom cam. Lift seems absurdly low to me for an LS7.
Not absurd for an engine with known valvetrain issues.......
G Atsma (11-29-2021)
Old 11-29-2021, 09:52 AM
  #33
grinder11's Avatar
Originally Posted by Mavn
Way over priced imo . Warranty isn't worth it imo ..99% of the time they won't cover it anyway. Build you a nice 416 that makes more at the tire than this engine does at the crank for less.
I agree X2 on the warranty. Sadly, warranties on engines today are just a reason in writing to find a way around covering the motor. Also, please note: I'm 99.999% certain GM requires that your Chevy dealer do the install, and you must also use (and purchase!) the supplied PCM, or the warranty evaporates. I'm reasonably certain that by the time the dealer installs this engine, you'll be knocking on 15 grand, IF you want the warranty. Personally, if I had to buy another LS7, I'd build the short block, and add non OEM heads. I had a lifter (LS7) break, and take the cam with it. My LS7 was supposed to have a warranty. When I talked to the builder, I was told 'all the parts your lifters are working with in the valvetrain are aftermarket racing parts, so there's no warranty.' Didn't talk that way when selling the package! Buyer beware!!!!
The following 2 users liked this post by grinder11:
Corona (11-29-2021), Jimbo1367 (11-30-2021)
Old 01-30-2022, 09:40 AM
  #34
99 Black Bird T/A's Avatar
Received 1,454 Likes on 1,008 Posts
Sad day chevy-ls7-discontinued.
Hoped we had a few more years of availability.
Old 01-30-2022, 09:57 AM
  #35
cino's Avatar
LS1Tech 10 Year
As long aftermarket parts are available, LS7 architecture will stay alive.
LS7 blocks are still available, probably not for long.
Darton sleeved gen IV blocks are better foundation to build LS7-style engine anyway.
Same for aftermarket heads.
01CamaroSSTx (01-30-2022)
Old 01-30-2022, 03:30 PM
  #36
Moderator
John B's Avatar
Couldn't agree more...if anyone knows of a new LS427/570 still in the crate I got cash!
Old 01-30-2022, 06:25 PM
  #37
grinder11's Avatar
I'll agree to disagree. I have a much better cam in my LS7 A4 C5, and I made right at 500whp. My tuner said I'd be at around 525whp if I had a M6 trans. So the LS7 570 might make 500, but it won't be easily, or by much. A lot depends on the brand of dyno, and the operator, too.
Old 01-30-2022, 06:28 PM
  #38
grinder11's Avatar
Old 01-30-2022, 06:47 PM
  #39
https://ls1tech.com/forums/dynamomet...yno-pulls.html
It definitely takes more than a crate LS7 with 505 fwhp to reach 500 at the tire. I don't even think its possible with an M6 running an aluminum driveshaft and a 10 bolt.
Old 01-30-2022, 07:14 PM
  #40
Received 3,247 Likes on 2,529 Posts
You show me ANY drivetrain that eats only 5HP from flywheel to tire, and I have a bridge for sale... . over some prime swamp land.... in the middle of a desert... right near the South Pole...
Quick Reply: LS427/570 LS7 from GMPP - Experience or Discussion
