LS427/570 LS7 from GMPP - Experience or Discussion
#82
Where’d My Horsepower Go? Drivetrain Power Loss & The 15% "Rule"
Better than average article on the topic.
#83
What are driveline losses? Why are there losses at all?
Friction.
Friction increases with the amount of force applied.
The ring and pinion is the biggest offender. It needs to change the direction of torque.
If a driveline took fixed power to turn you wouldn’t be able to turn the driveshaft by hand..
There are many other factors but the dominant one is friction between the gears and that is represented by percentage loss to estimate the frictional losses to heat.
Friction.
#84
Friction.
Friction.
The following users liked this post:
G Atsma (02-15-2022)
#85
Energy losses do change with speed and torque. Gears rub and scrub on each other (it's an imperfect mating), teeth bend under load, parts spin on bearings, lubrication shear forces, the list goes on. I'm not educated about fluid couplers (torque converter) but I do know it behaves different than gears.
Even without knowing any of that, you can see the evidence of this by rise in oil temps and the need for larger cooling systems as more power is carried by the drivetrain. And you can hear the difference in mechanical noise (sound is a form of energy loss). If you want a real sense of how things change with conditions, then you need to see the efficiency curves for the transmission and rear axle.
Also keep in mind the car can be rigged to report higher power level on dyno. Two cars with the same power plant can report pretty big differences depending on gear ratio, tire diameter, tire rubber compound, and whether the converter is loose or not.
#86
Friction.
Friction.
#87
Seriously though, this place allows a lot of social and off-topic discussion. That's why you have so many regulars that are here mainly for the social scene. Posting in tech threads is just part of that social scene, the topic doesn't matter, it's just another day at the club with the guys... And camaraderie is a good thing but the way this site is managed is getting you the "dark side" that you don't enjoy.
Hey, but cheer up and look on the bright side.... the average IQ here is way higher than Facebook.
G Atsma (03-11-2022)
The following 5 users liked this post by John B:
99 Black Bird T/A (03-11-2022), Corona (03-11-2022), G Atsma (03-11-2022), OldSchool3 (09-25-2022), Rich2342 (03-01-2023)
The following 3 users liked this post by old motorhead:
#90
old motorhead (03-11-2022)
The following 3 users liked this post by John B:
#94
MAN, that really sucks, dude!!! Sorry to hear that. I once had an '85 IROCZ 383 stroker stolen near Detroit. Got it back stripped but still had the 383 and drivetrain intact.....Been there. Always loved Elky's. My good friend once had an early 70s orange and black 454 SS El Camino. Just gorgeous.... Until his girlfriend found out he was cheating, so she took an axe to it outside a bar he was in. True story.......
John B (03-18-2022)
#95
Wish John B some luck !!!
We found a prestine 1970 SS 396 El Camino at the Mecum auction this weekend....checked it out yesterday and he's bidding on it this Saturday !!!
If you find it on a cable channel, watch it as he bids on the truck....... lot#30 I think.
Then the transformation begins
#96
Update on my LS427/570
Final dyno number was 491whp/455wtq, probably could have gotten over the 500whp mark, but my main goal was drivability so didn't spend too much time on maximizing power. Some more work is needed to clean up some of the dips in the curve, but I only have a couple hundred miles on the engine currently so I want to get all the changes I've made to the chassis dialed in. I didn't end up hitting my HP goal but I think that's mostly down to the headers I have. They're Borla 2010 Camaro Shorty headers. Borla claims the primaries are 1 3/4 but that's only the first half inch; they're actually 1 5/8 going into a ~2" collector. My exhaust is probably holding me back as well, it's 2.5" and built to be quiet. 1 7/8 longtubes should make a big difference, but since there are no off the shelf options that fit my RX8 I'm making a set myself, just didn't have time to finish before my scheduled dyno time.
Although I'm a little disappointed with the power numbers, it achieved most of what I wanted. In traffic it behaves the same as the stock LS3 I had before just with more grunt. No bucking or surging or other bad behavior even when it's lugging at low speed in 6th. It has a mild cam lope, but nothing obnoxious.
I need better tires, but traction is very limited in 1st-3rd. Once it gets traction it pulls hard and feels linear to redline. Happy overall, it got me most of the way to my goal, and kept the manners of a grand tourer. With a few changes it should end up at my power goal.
#98
By the time (4 Feb 22) I read that GM had discontinued the LS7/570, all of my main, online dealers were sold out. Over the course of the next few weeks, off and on, I kept looking online for some place that might be able to find one that wasn't spoken for yet. I eventually found Pro Touring Store and, at the time, they were still advertising the original, "pre-GM cancellation price of $13,399." I spoke with the owner, Dale and he started working with his Chevrolet dealers that he normally sourced engines from. After about 3 weeks, he found a dealer that had one on order and it didn't have a buyer. He secured that engine for me. I had to wait another 3 weeks or so before it actually came in to the Chevrolet dealer and was ready to ship to me.
The engine arrived at my house yesterday. I haven't removed it from the crate but I did open up the box to make sure that there was an engine in there and not a stack of bricks !
The only picture of the engine itself. Driver's side head.
John B (04-12-2022)
#99
I read through this entire thread and I have to admit that I didn't know about the valve guide issues that plague these LS7s. Had I known that, I'm not 100% certain that I would've purchased the engine. Anyway, I'm happy with my purchase and the LS7's future home is in my very first, original car-my second gen, 1980 Z28.
#100
@dannyual777 that's a fantastic find! 👏
Hope everything works perfect for your 80 Z28, that should make one hell of a crate motor LS7!
If GM would have just kept the LS7 around a little longer until July of this year, I might have joined the club too.
