L99 P0336 on hot oil
2011 chevy camaro SS 6.2 L99 stock 116K mileage.
I'm constantly haunted by this problem. After good driving (when I sit on the throttle pedal) car dont start correctly. I have slow cranking and Servise Stabilitrack comes on without CEL. With scanner I can see P0336 error. I have already replaced crank sensor several moth ago but issue remains.
Maked heat shield for the starter (this one), replaced negative battery wire, maked additional negative wire for the starter but nothing helps.
Could it be rod bearings issue ? When I drive as usual everything is OK (even when oil temp rises up to 250F) , but when I sit on the throttle and drive in Competitive Mode, I have this problem.
Anyway I should replace battery
I had ONE HELLUVA TIME with my 2000 C5, which has a torque tube, and the flex plate has a pinch bolt that clamps the female splines of the flex plate onto the male splines of the input shaft of the tube. Not familiar with the Fbody setup, BUT-If you have a similar pinch bolt/clamp arrangement, you MUST release the pinch bolt to check for crank endplay!!! My car threw the P0336 code ONLY once coolant temp hit 186°F. Hope this helps, and if you want to discuss it more, PM me, and I'll get back to you ASAP......
I hear a constant thud from the engine when I sit inside but it's impossible to capture on camera.
I know that crank bearings has the same symptoms :hard start on hot engine
Additional ground was made for the starter and engine but today again i looked to a slow cranking and no start after I have sit on the throttle pedal on highway
My car is stock and I did nothing with crankshaft. Yes, I've pulled harmonic balancer several times but I don't think this is the reason.
