Another "which oil" thread, but for a legit reason.
I'm assuming a heavier weight oil will help, and I was considering going to a 10W30, but I'm concerned that cold idle oil pressure could be enough to blow out my seals. Or am I overthinking it? Is my engine going to live at 7500 and 20 PSI of boost with 55 PSI of oil pressure? This is my first boosted engine build and I want to make sure it lives.
As Che70 points out, different filters can result in different oil pressure, depending on how well they flow. In general a more "effective" filter (better at trapping small particles) will necessarily flow more poorly and result in a greater pressure drop. I kinda think the Wix filter is one of the "better" ones as far as filtration, meaning it's likely to cause lower oil pressure. Filter choice in that sense is a compromise between effective filtration and unrestricted flow. There's no "best" choice in that regard although of course there are crappy filters and there are higher quality ones, it's more how you see your priorities as being ordered.
Thicker oil will obviously also increase the pressure drop in the filter.
Personally I think it's VERY POOR policy to run thicker oil just to make the gauge read higher. Precisely as he also stated: the engine need FLOW through the bearings, not PRESSURE. All that the pressure does, is create flow. You could probably literally put gear lube or candle wax in your motor and get HUNDREDS of psi; I doubt your bearings would like that very much though.
It's a law of physics. You want more flow, you gotta relieve restrictions. It's just that simple. Don't overthink it because "car"; it's STILL just a law of physics.
Personally, I'd suggest taking a look at the filter specs, and seeing if the impurities you expect to need to remove from your oil, are covered by a less restrictive filter. For example, if it removes (I'm just making up #s here, don't blame me if they don't match anything) 95% of all particles 2 microns or larger and 99% of all particles 5 microns or larger, and all the impurities you expect (dirt, debris, etc.) are 10 microns in diameter, then does the filter's performance at 2 microns REALLY justify accepting the restriction that the filter medium with smaller pores or more layers imposes? IOW, since it's all a game of NUMBERS, use NUMBERS to help you figure it out. FWIW, most metal debris particles are MUCH larger than most "dirt"; that's why people use screen filters for pure racing applications, is because even though they're not a particularly "effective" filter, they're all that's needed; if you keep the engine clean, like having a properly functional PCV system rather than breathers, you won't be getting much "dirt" in it ANYWAY. Or, if the only place you run the car is at the track, and it only drives 2 miles a weekend in the process, then how much "dirt" is it ever going to pick up, anyway? Think about stuff like that instead of just "big numbers on the gauge" eye candy and "most effective filter" even though it's not necessary (won't ever have small enough particles around that it needs to catch in the first place).
I'm reminded of the Super Stock guys back in the day (maybe they still do this way, I haven't been around that for a really long time) that used the LOWEST oil pressure and the thinnest oil they possibly could and their engine still survive for the teardown interval they're going to be following ANYWAY, because higher psi and thicker oil just waste engine power, if it's not really needed. The motor will make more power without the extra burden.
Seeing nice big psi #s on your gauge isn't worth a crap if the bearings are starved for oil flow. Which of course is the YYYYYYYUUUUUUUUUUUJJJJJJJJJJE problem with the old "10 psi per 1000" oversimplification. Yeah sure, you might be seeing a nice pretty 60 psi on your gauge at 6000, butt if there's no oil FLOWING through the bearings, then you're STILL not lubing them adequately. Just making random changes in whatever way just to make the gauge show big #s isn't some kind of rational approach.
The ones in trucks are longer than the F body ones. Not sure if that's A Good Idea, since the filter may hang down below your oil pan, and thus be highly vulnerable to road damage; butt worth looking into especially if that's not a concern (pure race / no street for example).
Here's what I could get from Mahle. Maybe you could cross-reference their part #s to whoever else and find the same physical size, then try to track down the micron ratings. They offer abuncha other threads besides these 2 butt those would be useless to us. Note that there are several part #s with the same external dimensions in some sizes; I would suspect that those have different micron ratings, especially since they're in several of the most popular sizes. I believe the stock F body filter is 3" x 3.4" more or less; some of the 6.0 trucks, and maybe the 6.2 ones, use a longer filter, like maybe 4.65". Iunno, didn't go drilling into it that deep.
Bottom line to me though, is how to get the most possible oil to/through the bearings. Artificially forcing the gauge read a higher # is useless if it doesn't result in more oil getting to the bearings. Since our oil pumps are essentially a constant-volume type, i.e. they move x amount of oil per rev regardless of anything else (and of course if some of that is air from a bad pickup O-ring, then that portion of the volume is NOT oil), and the pressure just ends up being whatever it happens to be based on how rapidly the pressurized oil can pass through the restriction of the filter, flow down the passages, and escape through all the clearances. The high limit to the pressure is the relief in the pump; so for example, if your relief spring is set to 65 psi, and there's 10 psi of pressure drop in your filter with your choice of oil, then the gauge will only read 55 BEST CASE, even though the pump is maxing itself out. This is where filter choice comes in; enough filter to keep the oil clean "enough", butt not SO MUCH that impedes the flow (and reduces the pressure in the whole rest of the system that comes after it). It would be possible to have VERY high pressure butt STILL have the bearings starve for oil, if the oil can't flow through the clearances adequately; and conversely, to have EXCELLENT lubrication at lower pressures, if the bearings are liberally bathed in oil and their surfaces kept from ever touching each other. Personally I'd prefer to err toward the latter condition; just jamming the gauge to a high number by using thick oil doesn't pass the smell test that way. OTOH the "ideal" viscosity is going to be based on clearances, expected contamination (a blown alcohol motor for example will almost certainly need thicker oil than a N/A gas one), oil change interval, filtration needs, and so on. Not to mention, YOUR own personal preference as to what order of priority all of those concerns are in, to YOU.
