LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   Cylinder Head Guru's. Repair question (https://ls1tech.com/forums/generation-iv-internal-engine/1984434-cylinder-head-gurus-repair-question.html)
Rich2342 Apr 1, 2026 10:24 AM
I have a like new set of aftermarket heads in which need a rocker bolt time sert repair for 1 of the rocker holes.
I plan on dropping the car off for upgrades along with the heads.
Will the proper time sert mess with the rocker geometry? Is it a reliable fix?
https://cimg7.ibsrv.net/gimg/ls1tech...2aa599e521.jpg
https://cimg9.ibsrv.net/gimg/ls1tech...92df833dae.jpg
RB04Av Apr 1, 2026 11:03 AM
I'm no "guru", butt...
No. Assuming proper installation as well as using the proper insert of course.
​​​​​​​Is it a reliable fix?
Probably.
I tend to Heli-Coil all of those on heads anymore, they tear up so often, especially used heads where they've been gorilla'ed befor I ever got em. Those teeny tiny fine threads in aluminum are kinda too close to a one-use-only thing, it seems.
Scott Danforth Apr 1, 2026 11:25 AM
timesert is fine, a better repair than a helicoil
gnx7 Apr 1, 2026 11:42 AM
Timesert always better than helicoil
grinder11 Apr 1, 2026 12:27 PM
Depends on how much material surrounds the damaged thread. A Heli-Coil is stronger than the original thread. It is all that is needed. Please explain why the threaded insert is "better." Heat transfer properties will be more affected with a threaded insert than a Heli-Coil, along with possible dissimilar metal reaction in aluminum. Heli-Coils are stainless steel wire, and have no galvanic/dissimilar metal reaction in aluminum. AFR has used Heli-Coils on all their heads threaded holes for many years. If one was better than the other, I'd think AFR would've used inserts everywhere they could have....
RB04Av Apr 1, 2026 12:33 PM
I recall Xler service manuals from the mid 60s, when those cars were brand new... the automatic transmission section gave you the steps of rebuilding a 727 or 904... step 1 was teardown, step 2 was cleanup, step 3 was "Heli-Coil every bolt hole"...
Rich2342 Apr 1, 2026 01:03 PM
I would tend to think so on aluminum material..
Scott Danforth Apr 1, 2026 01:46 PM
Originally Posted by grinder11 (Post 20645015)
Heli-Coils are stainless steel wire, and have no galvanic/dissimilar metal reaction in aluminum. ...
aluminum and stainless together are the epitome of galvanic corrosion. just add a bit of salt or a stray current to start the reaction. add a copper washer and you can power a lightbulb.
look at the galvanic chart. they literally are on the opposite ends of the chart.
https://cimg0.ibsrv.net/gimg/ls1tech...82cc19774d.png
timeserts or other threaded inserts are usually hardened inserts, the standard material is steel, however you can also get them in 303 stainless as well as about a dozen other materials. you choose the exterior threads by the material you are going into, irrespective of the fastener thread pitch or diameter. you must tailor the insert to the application. they are for cyclical loading, and considered a permanent repair. it is also what GM and Toyota specify for head fastener hole repair in aluminum blocks.. where helicoils are a band-aid approach, governed by the thread pitch of the fastener. one wrong slip with the over-sized tap and you can ruin what you are working on.
Rich2342 Apr 1, 2026 01:54 PM
So in essence, what? 😄
Time sert good, Heli coil bad.
Che70velle Apr 1, 2026 08:51 PM
Sure, a TimeSert repair is overall stronger and a more permanent solution to a problem. If I’ve got a hurt threaded hole in an aluminum head, block or whatever, and I can’t afford to go to a larger size because of space, or other constraints, I’ll use a TimeSert if and only if it’s a high torque application. A HeliCoil on the other hand is useful for low torque applications in a REPAIR situation. I’ve had my hands in a lot of high end builds over the last 30 years and I can assure all of you that the very top endurance engine builders install HeliCoils in most all threaded holes in both aluminum blocks and aluminum heads, while the unit is new, to help avoid threaded hole issues later, before they start. As a preventative defense, before there’s a problem, it’s smart. In a high torque repair situation, after the problem has occurred, it’s a bandaid at best.
Rich2342, a TimeSert here is smart and will not affect geometry at all as long as the machined surface HEIGHT where your rocker arm stands sit isn’t altered. On the other side of that, if this is an 8mm rocker bolt, it won’t see over 26 ft lbs, and a properly done HeliCoil will suffice. If it’s a 10mm bolt, it will see too much torque for a HeliCoil…in my opinion…and I personally would revert back to the stronger, and more expensive TimeSert repair here, if this were in my shop.
Rich2342 Apr 2, 2026 06:31 AM
I would hope most shops can perform a proper time sert, but that is my concern.
I am not sending the heads out to a machinist who I would be fairly confident things would be precisely measured and fixed.
I just assume buy a new set of heads if this is something iffy for a shop to get right. I don't want the rocker coming out or side loading the valve tip, dropping a valve.
grinder11 Apr 2, 2026 09:12 AM
Sounds like your mind is made up. I wish you the best of luck. The only things I'll add are:
GM used plain cast aluminum for threads, and it works for 99% of us. AFR uses heli-coils as standard equipment, and I've never heard of any issues with them, so they work. I doubt you'll experience any galvanic reactions when said thread lives in an oil bath. Again, hope it will work out no matter what route you take.
grinder11 Apr 2, 2026 09:56 AM
Please note the difference in Active and Passive 304 stainless. USUALLY, active 304 is used for heli--coils....
Rich2342 Apr 3, 2026 06:20 PM
Actually no..
Found a machinist and dropped them off today.
They need a cleanup cut, so while I'm in there...
What is the correct deck clearance on sbe ls3? Ive seen anywhere from .005 to .007, used.
11 degree 260 heads with 69cc chambers out of the box.
https://cimg9.ibsrv.net/gimg/ls1tech...449571540c.jpg
© 2026 MH Sub I, LLC dba Internet Brands
