Notices
LS2 TB...is it 90mm all the way? No lip or anything?
Old 11-20-2004, 08:58 AM
Another_User's Avatar
Default LS2 TB...is it 90mm all the way? No lip or anything?
Just curious to see if there is some design plan that GM follows, or if they did away with that on the LS2.
Another_User is offline
Old 11-20-2004, 10:55 AM
Nasty N8's Avatar
They all come stock with a lip it helps in low speed driving.
Nate
Nasty N8 is offline
Old 11-20-2004, 12:12 PM
Nate
I suspected as much. Thanks!
Old 11-20-2004, 07:22 PM
Project GatTagO's Avatar
The lip helps tremendously with low speed drivability.
Andrew
Project GatTagO is offline
Old 11-20-2004, 07:56 PM
Andrew
Is the purpose of the lip to keep light throttle from allowing too much air in?
Old 11-20-2004, 10:00 PM
Nasty N8's Avatar
Just from causing a vortex and stiring things up.
Nate
Nasty N8 is offline
Old 11-21-2004, 09:29 AM
The lip is there so that at low throttle blade angles there is less air flow. After about 20 degrees of blade opening, the lip has no effect. The reason aftermarket TB have no lip is that its a lot harder to make the TB with the lip.
Andrew
Old 11-21-2004, 06:56 PM
chpmnsws6's Avatar
is it a restriction at WOT (on the ls1 throttle body)
chpmnsws6 is offline
Old 11-21-2004, 07:08 PM
gojo's Avatar
Andrew
NW TB has the lip.
gojo is offline
Old 11-21-2004, 09:20 PM
NW?
Andrew
Old 11-21-2004, 09:25 PM
gojo's Avatar
NW?
Andrew
Sorry, I forgot that Nick Williams TB is for fly by wire.
"The lip is there so that at low throttle blade angles there is less air flow. After about 20 degrees of blade opening, the lip has no effect. The reason aftermarket TB have no lip is that its a lot harder to make the TB with the lip."
You are right about this.
gojo is offline
Old 11-21-2004, 10:33 PM
Hey gojo, have you check out my thread in the PCM forum? Bink mentioned that you might have an interest in my thread. The point is related to this.
https://ls1tech.com/forums/pcm-diagnostics-tuning/241072-surging-bucking-related-how-much-does-timing-affect-airflow-requirements-rambling.html
Quick Reply: LS2 TB...is it 90mm all the way? No lip or anything?
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
