Has anyone actually dynoed a LS2 402 stroker yet?
Has anyone actually dynoed a LS2 402 stroker yet? I have ordered mine from ARE and I'm curious as to whether 480-520 RWHP is unrealistic
I will have:
-ARE stage 3 5.3 heads with 2.055 in 1.57 ex opened up to 4.0 bore
-not sure of cam yet 240-250 .610-.630ish
-Pro Magnum rockers
-LSX 78 w/ ported TB
-Racetronics pump
-SVO 30# may need bigger
-QTP 1 3/4 to catted Y to Magnaflow
-Moser 12 bolt 3.73 33 spline
-steel DS
-spec 3 in a M6
-likely MSD coil packs
What do you think?
I have seen 408's in the 500 + range.
Thanks in advance,
Rampant
I will have:
-Pro Magnum rockers
-Racetronics pump
-steel DS
-spec 3 in a M6
What do you think?
Thanks in advance,
Rampant
There are the APE 408 and SLP 402 reviews on my webpage @ www.avigdor.net ... another way to calculate your results will be take mine and yours will be a little bit slower
Just playing with ya!
You should pick up about .5-.75 in the 1/4... mid to low 11's... this is where we both should be... then take off another .75 for my 150HP wet kit... mid 10's here I come!!!
I'll have to see if I can maintain my 60ft advantage
I think that it comes from my extra 60lbs over the rear axle. Though I'm trying to get rid of at least 30 or more by spring. And 2" of the waist New Years
Rampant
I will have:
-Pro Magnum rockers
-Racetronics pump
-steel DS
-spec 3 in a M6
What do you think?
Thanks in advance,
Rampant
I will have:
-Pro Magnum rockers
-Racetronics pump
-steel DS
-spec 3 in a M6
What do you think?
Thanks in advance,
Rampant
How do you know you'll even get a real LS2 or even a motor?
I hope you meant APE!!
Have not seen the 7.0 block in person yet. That engine will probably be over a year before we see them turning up.
Kurt
Kurt
Originally Posted by JS
Wow,580 thats impressive Kurt for a mild LS2 402..When do u think you'll be getting alum 7.0 blocks so we can build say a 414 or 418 LS2 w/a good rod ratio/piston speed?
LS1TECH Sponsor
I have one going together here now. I should have some numbers for you by end on January. It will be a mild street motor with a small cam and AFR 205 heads. Customer wants a "torque monstor".
Mikey
Mikey
Yes I did mean ARE. I also did look into APE and heard good and bad about them as well. I wanted to look at all my local options.
I was one of the first new customers for ARE's new management last year. I recieved nothing but great customer service. As for a real LS2 I have already seen it first hand. They did great work on my head and cam package last year, it made good numbers and was very reliable.
Anyway this was not about vendors but what kind of results have been seen so far for this new set up.
580fwhp certainly would suggest that 480-500rwhp in a conservative setup may be possible.
427 what cam did you use and what bolt ons? If you had an earlier thread could you point me to it please.
Thanks again
Rampant
Thanks again
Rampant
It was a engine we built to do some dyno testing to come up with a C6 package. It had headers and a Donaldson filter for bolt ons.
There was no "thread" about it.
It had a low (800) rpm idle that was very steady.
Kurt
Kurt
Thanks again
Rampant
Thanks again
Rampant
Kurt
Kurt
Thanks again
Rampant
Thanks again
Rampant
