LS7 Oil Pan on an LS2?
Is this possible? Searches revealed results for using an LS2 pan on an LS1/6, but nothing for my specific situation.
As for the drive type, it should be the same as the LS2, since the drive sprocket position is identical. If it is not, I plan on using a custom crank anyway, so I will just have it made to spec for compatibility.
The other issue that I was concerned about (and have no more worries about anymore) is the difference between pump lengths between the LS2 and LS7. Since the LS7 uses a 2 stage pump, this pump should protrude out further from the front of the engine, and perhaps 'not fit in the block' properly. Upon closer inspection of both LS2 and LS7 cutaway shots, I see that the pump is not located inside the block at alll, but rather externally in the front, behind the timing housing cover.
I would need to use the LS7 timing cover to ensure enough room for pump fitment.
The last issue that appears to need assesment again deals with compatibility between block and pan: proper lineup of the oil passageways between the block and pan. I would assume that they would be identical, but I would like confirmation that the discharge port of the secondary pressure stage is compatible with the block oil gallery that would accept the pressurized oil.
