LS7 GM crate motor part# = 17802397
Old 03-30-2005, 12:21 PM
  #41
Restricted User
NOSjohn's Avatar
*YAWN* ...I can't wait for August! You guys and girls can guess over on LS7power and win a BOSE interface. All the speculation is cool though...so many ideas.
Old 03-30-2005, 03:05 PM
  #42
black_z's Avatar
Im guessing 15-18K
Old 03-30-2005, 03:46 PM
  #43
bad0211secws6's Avatar
my parts manager called spo today they told him pricing will be listed on july 15th
Old 03-31-2005, 09:41 AM
  #44
technical's Avatar
I'm guessing the LS7 crate will cost ~20k.
20k more than I have...
Old 04-02-2005, 01:29 PM
  #45
SSU'S Vice Mod
sb427f-car's Avatar
Originally Posted by 02SOMWS6
I'm planning on peiceing mine together, could care less how much a crate engine is.How much is the bare block, heads and intake?I'll get a stroker crank ,forged pistons and rods and a real big cam.Going this route should be around ?????????????
Exactly. You definately don't need the Ti rods. That crank would be nice to have though.
Old 04-02-2005, 01:45 PM
  #46
SSU'S Vice Mod
sb427f-car's Avatar
Originally Posted by 93LS1RX7
Do you honestly think a LS1/6 wiring harness will work with this new motor? Hell the LS1 doesnt work with the LS6 3 vs 5 wire MAF, fly by wire etc.
These arent going to be mass produced I would guess too. They are hand built motors.
Now the big savings could come in if things like the block are cheaper than a C5R block or a aftermarket sleeved block but we will see.
Yeah, bare cast blocks can be massed produced pretty easily, as long as there is a market for them. Even with pressed in liners these can be quickly cleaned with the right production methods and shipped out the doors.
Old 06-13-2005, 03:37 PM
  #47
Tuan Le's Avatar
Time to bring this thread back to life!!! Now that they've already released the price for the new Z06 ($65,000 base), I look forward to the price for the LS7 crate motor.
Old 06-13-2005, 04:42 PM
  #48
Rottluver's Avatar
Someone posted in the NW forum a week or two ago.,....I don't have the link but they (GM) were saying upwards of $15k for the motor......
Old 06-13-2005, 05:43 PM
  #49
02SOMWS6's Avatar
You could peice one together to make more power for less
Old 06-13-2005, 05:50 PM
  #50
11 Bravo's Avatar
If that motor is 15K or more than I doubt too many here will buy it. You can build a more powerfull 427 for less. I still want to know how much the damn heads and intake will cost. I think that could be the next hot setup if the price is comparable to what we have now.
Old 06-13-2005, 11:44 PM
  #51
Dbluegoat's Avatar
$14,000
Old 06-14-2005, 01:11 AM
  #52
BlueSix's Avatar
No you can't.
Old 06-14-2005, 11:32 AM
  #53
11 Bravo's Avatar
Originally Posted by BlueSix
No you can't.
Yes you can.
Old 06-14-2005, 11:54 AM
  #54
slt200mph's Avatar
Only in your dreams..check and see what a C5R block cost plus the rest of the motor or if you want to have Darton sleeve a LS1 or LS6 block...the LS7 crate motor will be the best bang for the buck in a all aluminum 427 cu. in. small block...plus it will have a warranty...all it will need is a good cam and a good exhaust system..you could polish the heads but that will only gaine a few HP they are CNC 12 degree angle heads that are basically the C5R racing heads...if you check and see what it will cost to buy the parts and have the machine work done to build your own you will spend more in the long run...
  #55
Steve1969LS1's Avatar
I wonder how people will tune it since it is not table based like LS2, LS6, LS1 engines..
It is MATH based in the ECM.. you need to be a real geek to mess with the ECM..
Hey.. you can see the motor built here:
http://popularhotrodding.com/tech/0507phr_gm/
Old 06-14-2005, 01:25 PM
  #56
Moderator
John B's Avatar
Just like me....use an LS1 PCM!
Old 06-14-2005, 05:59 PM
  #57
BlueSix's Avatar
Originally Posted by 11 Bravo
Yes you can.
No, you can't.
It's not a sleeved LS1 block, so to build anything comparable you will need a C5R block. the heads are C5R based.....good luck getting an aftermarket head to flow the numbers that the LS7 head will flow.
A comparable engine could not be built for the same price.
Old 06-14-2005, 06:18 PM
  #58
11 Bravo's Avatar
No, you can't.
No one said you could build a 427 with a C5R block for less. You can build a more powerful 427 for less. The block don't make any horsepower. If you want to talk about potential with the LS7 heads, well, that's another subject and I would agree with you. But, yes, you can build a more powerful 427 for less. Much less if you shop smart.
Old 06-14-2005, 06:20 PM
  #59
Rottluver's Avatar
I think the disagreement was that someone could build an "LS7" for cheaper then GM will sell the crate motor for...............that is how it seemed to me.
Old 06-14-2005, 06:24 PM
  #60
11 Bravo's Avatar
Oh, in that case I would agree you could not build one for less, then. All I know is I look forward to the day a new Z06 pulls next to me And, minus the thousands of dollars an ex-sponsor stole from me, my motor cost quite a bit less than 15K.
Quick Reply: LS7 GM crate motor part# = 17802397
