New motor runs but no oil pressure, HELP!!!
Hey guys,
I finally got the car to start but I have no oil pressure. I took off the front cover and oil shoots out of the oil passage there and I also removed the block plate above the oil filter and oil shoots out there. The car shows no oil pressure at the guage and I pulled a valve cover and no oil is coming out the rockers.
Two questions, are my bearings getting oil? Any ideas what is going on? The motor is brand new built by Scoggin Dickey. Any help would be greatly appreciated.
Originally Posted by VTESPEED
I ended up having to rebearing my motor after the same problem on 408". I only ran it just 15-20 seconds total over several starts. dont start it till you find the problem.
There is a plug on the front behind the timing cover that was missing. It pumped 5-10 psi of oil pressure but the rest went right out the front hole. Is that plug there? also is the plastic plug in the back in?
Originally Posted by NEW402
Hmmm, I don't remember installingt any plugs under the front timing cover. Can you tell me where exactly it is. Also, where is the one in back you are talking about? I that one beneath the rear cover? Sounds like you might be on to my problem, can you let me know where these plugs are? Thanks a lot.
