new ls2 402 slp stroker with check engine light
i have recently had a ls2 stroker installed from slp with stage 3 ported afr heads from TEA.My engine ws first throwing a tsb throttle body code and would not idle at 1000 rpm,so i adjusted the throttle body to keep the car idling at 1000,and no morre tsb code,now its throwing a po106 code which is a barometric pressure code for the manifold pressure/i have the T-rex cam from thunder racing i have only 85miles on the car and will be down another2-3 weeks until strange sends me another rearend mine tore up after 85 miles,i have the worst luck shew,,but in the mean time i would like to get the engine ready and to figure out why the car is throwing this code ,it only throws codes while sitting and first idling ,while driving it has not had any engine codes,,does anyone have a suggestion or resolution,plan on dyno tuning if i can get at least500 miles on the car,,bryan from pcm for less done the programming.
