A couple ls2 Q's Are the cam and crank sensors the same? Anyone have the part # for the vale cover? And will my Ls1 rear cover work or not? |
Crank sensor is the same.. The cam sensor is different and actually on the timing chain, so you'll need a LS2 timing set and front cover. The rear cover will work. I have built 4 or 5 stroker LS2's. all 500+ RWHP |
These are the numbers cast underneath the valve covers: 12570697 CAV 18 <---- has oil filler 12570696 CAV 21 |
I meant the valley covey sorry. |
And also can you change the wiring to hook the cam sensor up to the ls1 msd system I am going to run with my carb setup |
I am dumb i just saw the conversion harness by racetronix |
Originally Posted by 89lx-ls1 I meant the valley covey sorry. |
Thats what I was looking for!! :nod: |
| All times are GMT -5. The time now is 04:47 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
