LS2 TB harness connector P/N?
• OEM: 15355474
• Service: 15306420
Pin
Wire Color
Circuit No.
Function
A
BN
582
TAC Motor Control - 2
B
YE
581
TAC Motor Control - 1
C
TN/WH
1704
Low Reference
D
D-GN
485
TP Sensor 1 Signal
E
L-BU/BK
1688
5-Volt Reference
F
PU
486
TP Sensor 2 Signal
• Service: 15306420
Pin
Wire Color
Circuit No.
Function
A
BN
582
B
YE
581
C
TN/WH
1704
Low Reference
D
D-GN
485
TP Sensor 1 Signal
E
L-BU/BK
1688
5-Volt Reference
F
PU
486
TP Sensor 2 Signal
If you're looking for a conversion harness from the LS2 to a LS1? There are some PnP harnesses out there for ~$50 which will eliminate all the wire cutting and splicing. Check Xtreme Motorsports if that's what you're after.
Thanks a lot guys.. I think the conversion cable will do. It appears that the LS7 TB uses the same type connector - at least from a quick glance. Anyone know if the pin out is the same?
If so, I'll probably just order one of those cables. Thanks again for the info.
