Rapid Motorsports LS2 402 N/A Track Results
Sweet. I'm glad to hear the stock injectors are holding up. I was worried mine wouldn't be enough. Do you know what duty cyle they are at? What did the car put down rwhp/rwtq?
I wanted Rapid to build mine but got a Texas Speed.
That is some nice times and awesome mph there. Let us know when you get some knew dyno numbers.
Originally Posted by speedracer5532
I drove the car 150 miles to the track, ran it, and drove 150 miles back home.
RMS? daayum!!!
#32
Originally Posted by TAGOES11S
So the time's posted are with the solid roller? Any before/after comparisons between the cam's?
#33
Wow, congrats. 130 MPH traps NA with a 3700 lb race weight is nuts. Imagine that combo in my car with a 3400 lb race weight. If (when) I get a 402, Mikey will be building it.
#35
Originally Posted by robz*
Nice going!
Nice seeing you today. Mike @ Rapid is the one that is building my engine. He is really really good at what he does. Plus he is a super nice guy. Speak to you soon
Neil
#36
Race your car!
These are promising results, I am going to have a 402 built myself after having a problem with my stock bottom end AFR's are on teh bill as well as teh fast 90/90.
Do you think that the 1 7/8 headers are needed, or were you already runnign them? I already have 1 3/4 QTP's and was gonna at least try them to start, and try a cam in the 242/248 rance, maybe a little more lift then you are running.
#37
#38
AFR 225 heads milled .018 for a 11.5 CR, Rapid Motorsports cam 248/250 612/610 113 LSA, Fast 90 Intake with Nick Williams TB, Kooks 1 7/8 headers, Moser 12 bolt with 4.30 gears.
#39
Originally Posted by dhdenney
I see here later in the post where you clarified that the times were with this hydraulic cam. But what are the specs on your new solid roller? Why the change? Possible valve float?
#40
I was thinking of doing a solid roller LSx motor in the future so that's why I ask. Where do you shift at? I've gathered that with the EFI Live you are using, one can make the stock PCM go to 8K.
