Cam for 408?
iron 408
ET performance 240 heads
90/90 set-up
kooks 1 7/8
has every bolt-on
and fuel system
Car in Sig!
Car will be a A4 and spray 200 TNT shot. Car in sig. What size cam would you recommend to be streetable and make awsome power. Wife will drive sometimes!
But for off the shelf grinds a 244/248 will work nicely. If you have enough Static compression you could probably run something like a 250/257 on 114 lsa with an X-E style lobe as it would work great with your 3800 stall. Don't know how high you want to shift though.
Nate
