Who sells the plug-n-play harnesses for LS1 to LS2?
LS1TECH Sponsor
Originally Posted by Orange Peel
Is it a better thing to do??? I will email if you think so?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
-2 version is a matter of preference / application.
LS1TECH Sponsor
Well I emailed anyways, I would rather have the better heat withstanding of the -2 setup, if it works the same, then we are in good shape Better to be safe than sorry when a wire gets burnt
__________________
>WEB SITE<
>WEB SITE<
Which knock sensors do you have to use when using the LS1 ECM on a LS2 engine. I was under the impression the location of the sensors could cause problems ??? Are the sensor terminals different between the two engines? Thanks guys
LS1TECH Sponsor
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by LeMansBlue04
Hey guys, just a heads up. I recently put an LS2 stroker in a 2004 Corvette. I ordered the Racetronix cam sensor extension thinking it was wired so that it would work with my LS1 PCM. This was not the case. As soon as the tuner tried to start the car it started throwing cam sensor codes. They swapped the two outside wires on the connector and it cleared up the problem.
I don't know why it was not wired to work with the LS1 PCM. Kris at SDPC is going to get in touch with Racetronix and find out what happened. He said that when they ordered these units they told Racetronix they would be used for an LS2 with an LS1 PCM. It's not hard to change the wiring if you have to but you might want to make absolutely sure you are getting what you expect when you order the harness.
Originally Posted by FCar2000TA
Are the LS1 computers able to read the LS2 knock sensors yet?
Copied from EFILive's Tuning tool
The PCM can be used with two types of knock sensors, this parameter allows you to select which type of sensor is fitted to the engine.
The standard LS1 sensor is a resonant type, these sensors are connected like so -
Sensor Bank #1 - J1,pin56
Sensor Bank #2 - J1,pin11
If the engine is fitted with flat response sensors (like the LS2 uses), then the connections are like so -
Sensor Bank #1 GND - J1,pin49
Sensor Bank #1 Signal - J1,pin09
Sensor Bank #2 GND - J1,pin50
Sensor Bank #1 Signal - J1,pin10
Only the following values may be entered into this table:
- Resonant (LS1)
- Flat Response (LS2)
- Resonant (LS1)
#33
Originally Posted by Dragaholic
So do I need to run the knock sensors or not? This will be a drag only car. If I did do away with them, how would I fix it up computer wise. Lastly, will there be any negative affects by doing away with them? Thanks.
